[fdo-users] 3.3 GDAL provider does not work with MrSID plugin
Tom Fukushima tom.fukushima at autodesk.com
Mon Nov 19 11:39:05 EST 2007
Hi Frank,
Here is my "poke".
Thanks for doing this for us.
Tom
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam (External)
Sent: Tuesday, November 06, 2007 2:37 PM
To: FDO Users Mail List
Subject: Re: [fdo-users] 3.3 GDAL provider does not work with MrSID plugin
Tom Fukushima wrote:
> Hi Frank,
> I was trying out the FDO 3.3 GDAL provider for the next MGOS 2.0 release
> but found that when I tried to use the MrSID and ECW addons
> (http://home.gdal.org/dl/mapguide/) that I got the following error:
> "The application has failed to start because gdal13.dll was not found.
> Re-installing the application may fix this problem."
> FDO 3.3 now uses gdal14.dll.  Could you make us some new MrSID and ECW
> plug-ins that are compatible with gdal14.dll.  The exact version in the
> dll is 1.4.0.0.
Tom,
Yes, I'll try and get produce these.  Feel free to poke me if you don't
hear anything with a week or so.
Note that a 1.4 compatible plugin should work with any GDAL 1.4.x release
(1.4.0 through 1.4.3 or the eventually 1.4.4).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
