[fdo-users] Problem with C++ application with OGR provider
Bruno Scott bscott at geomapgis.com
Fri Nov 23 10:59:32 EST 2007
Depends shows that in FDOCOMMON.DLL ?Release at FdoIDisposable@@QAEHXZ is
missing
i have fdo2fdo with the same ogrprovider.dll , and it fdo2fdo connect
without errors.
So i must do something wrong.
Traian Stanev wrote:
> It means it couldn't find the function CreateConnection() in the provider
> dll. I don't remember whether I compiled the 3.2.2 OGR binary with VS SP1
> or not and whether that would make a difference. It's worth it to use
> depends.exe to check if the provider is missing any dependencies.
> Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
> Sent: Friday, November 23, 2007 10:00 AM
> To: FDO Users Mail List
> Subject: RE: [fdo-users] Problem with C++ application with OGR provider
> Can you send me the app? I will try it and see what I find.
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Friday, November 23, 2007 5:34 AM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Problem with C++ application with OGR provider
> I have a small MFC C++ application builded with Visual studio 2005
> I successfully use it with all osgeo provider ecept for OGR
> I compile against the fdo 3.2.2 binaries and i use the ogr provider 3.2.2
> binary
> As soon as a try to connect to the ogr provider
>     FdoPtr<FdoIConnection>             connectionPtr;
>     static IConnectionManager*         pConnectionManager             =
> NULL;
>     pConnectionManager = FdoFeatureAccessManager::GetConnectionManager();
>     connectionPtr =
> pConnectionManager->CreateConnection(_T("OSGEO.OGR.3.2.2"));
> I got this message in visual studio
>     'FDLWizard.exe': Loaded OGRProvider.dll', No symbols loaded.
>     First-chance exception at 0x76df3baf in FDLWizard.exe: 0xC0000139:
> Entry
> Point Not Found.
>     'FDLWizard.exe': Unloaded OGRProvider.dll'
> And it finnaly throw an exception
>     Unable to load the FDO Provider: The specified procedure could not be
> found.
> Someone has a idea?
> Bruno
> http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13909997
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13914578
More information about the fdo-users mailing list
