[fdo-users] Problem with C++ application with OGR provider
Traian Stanev traian.stanev at autodesk.com
Fri Nov 23 11:04:30 EST 2007
Looks like some of your dlls are 3.2.1 and others are 3.2.2.
The signature of FdoIDisposable::Release was changed between those two releases.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Friday, November 23, 2007 11:00 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] Problem with C++ application with OGR provider
> Depends shows that in FDOCOMMON.DLL ?Release at FdoIDisposable@@QAEHXZ is
> missing
> i have fdo2fdo with the same ogrprovider.dll , and it fdo2fdo connect
> without errors.
> So i must do something wrong.
> Traian Stanev wrote:
> > It means it couldn't find the function CreateConnection() in the
> provider
> > dll. I don't remember whether I compiled the 3.2.2 OGR binary with VS
> SP1
> > or not and whether that would make a difference. It's worth it to use
> > depends.exe to check if the provider is missing any dependencies.
> > Traian
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
> > Sent: Friday, November 23, 2007 10:00 AM
> > To: FDO Users Mail List
> provider
> > Can you send me the app? I will try it and see what I find.
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> > Sent: Friday, November 23, 2007 5:34 AM
> > Subject: [fdo-users] Problem with C++ application with OGR provider
> > I have a small MFC C++ application builded with Visual studio 2005
> > I successfully use it with all osgeo provider ecept for OGR
> > I compile against the fdo 3.2.2 binaries and i use the ogr provider
> 3.2.2
> > binary
> > As soon as a try to connect to the ogr provider
> >     FdoPtr<FdoIConnection>             connectionPtr;
> >     static IConnectionManager*         pConnectionManager
> > NULL;
> >     pConnectionManager =
> FdoFeatureAccessManager::GetConnectionManager();
> >     connectionPtr =
> > pConnectionManager->CreateConnection(_T("OSGEO.OGR.3.2.2"));
> > I got this message in visual studio
> >     'FDLWizard.exe': Loaded OGRProvider.dll', No symbols loaded.
> >     First-chance exception at 0x76df3baf in FDLWizard.exe:
> 0xC0000139:
> > Entry
> > Point Not Found.
> >     'FDLWizard.exe': Unloaded OGRProvider.dll'
> > And it finnaly throw an exception
> >     Unable to load the FDO Provider: The specified procedure could
> not be
> > found.
> > Someone has a idea?
> > Bruno
> > View this message in context:
> > http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-
> provider-tf4860799s18162.html#a13909997
> > Sent from the fdo-users mailing list archive at Nabble.com.
> > http://lists.osgeo.org/mailman/listinfo/fdo-users
> View this message in context: http://www.nabble.com/Problem-with-
> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13914578
More information about the fdo-users mailing list
