[fdo-users] Problem with C++ application with OGR provider
Bruno Scott bscott at geomapgis.com
Fri Nov 23 11:26:23 EST 2007
i used ListDlls.exe to show what dlls are loaded with by my apps and it shows
the good directory.
In this directory all fdo dlls are have version 3.2.2.65
except for xalan,xercess and gdal of course, that are not fdo dlls.
OGRProvider.dll does not show any file version :(
Traian Stanev wrote:
> Looks like some of your dlls are 3.2.1 and others are 3.2.2.
> The signature of FdoIDisposable::Release was changed between those two
> releases.
> Traian
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>> bounces at lists.osgeo.org] On Behalf Of Bruno Scott
>> Sent: Friday, November 23, 2007 11:00 AM
>> To: fdo-users at lists.osgeo.org
>> Subject: RE: [fdo-users] Problem with C++ application with OGR provider
>> Depends shows that in FDOCOMMON.DLL ?Release at FdoIDisposable@@QAEHXZ is
>> missing
>> i have fdo2fdo with the same ogrprovider.dll , and it fdo2fdo connect
>> without errors.
>> So i must do something wrong.
>> > It means it couldn't find the function CreateConnection() in the
>> provider
>> > dll. I don't remember whether I compiled the 3.2.2 OGR binary with VS
>> SP1
>> > or not and whether that would make a difference. It's worth it to use
>> > depends.exe to check if the provider is missing any dependencies.
>> > Traian
>> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
>> > Sent: Friday, November 23, 2007 10:00 AM
>> > To: FDO Users Mail List
>> provider
>> > Can you send me the app? I will try it and see what I find.
>> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott
>> > Sent: Friday, November 23, 2007 5:34 AM
>> > Subject: [fdo-users] Problem with C++ application with OGR provider
>> > I have a small MFC C++ application builded with Visual studio 2005
>> > I successfully use it with all osgeo provider ecept for OGR
>> > I compile against the fdo 3.2.2 binaries and i use the ogr provider
>> 3.2.2
>> > binary
>> > As soon as a try to connect to the ogr provider
>> >     FdoPtr<FdoIConnection>             connectionPtr;
>> >     static IConnectionManager*         pConnectionManager
>> > NULL;
>> >     pConnectionManager =
>> FdoFeatureAccessManager::GetConnectionManager();
>> >     connectionPtr =
>> > pConnectionManager->CreateConnection(_T("OSGEO.OGR.3.2.2"));
>> > I got this message in visual studio
>> >     'FDLWizard.exe': Loaded OGRProvider.dll', No symbols loaded.
>> >     First-chance exception at 0x76df3baf in FDLWizard.exe:
>> 0xC0000139:
>> > Entry
>> > Point Not Found.
>> >     'FDLWizard.exe': Unloaded OGRProvider.dll'
>> > And it finnaly throw an exception
>> >     Unable to load the FDO Provider: The specified procedure could
>> not be
>> > found.
>> > Someone has a idea?
>> > Bruno
>> > View this message in context:
>> > http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-
>> provider-tf4860799s18162.html#a13909997
>> > Sent from the fdo-users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > http://lists.osgeo.org/mailman/listinfo/fdo-users
>> View this message in context: http://www.nabble.com/Problem-with-
>> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13914578
View this message in context: http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915066
More information about the fdo-users mailing list
