[fdo-users] Problem with C++ application with OGR provider
Traian Stanev traian.stanev at autodesk.com
Fri Nov 23 11:28:21 EST 2007
Does your fdo2fdo use an FDO.dll that is local to its exe directory? What version is that dll if it exists?
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Friday, November 23, 2007 11:26 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] Problem with C++ application with OGR provider
> i used ListDlls.exe to show what dlls are loaded with by my apps and it
> shows
> the good directory.
> In this directory all fdo dlls are have version 3.2.2.65
> except for xalan,xercess and gdal of course, that are not fdo dlls.
> OGRProvider.dll does not show any file version :(
> Traian Stanev wrote:
> > Looks like some of your dlls are 3.2.1 and others are 3.2.2.
> > The signature of FdoIDisposable::Release was changed between those
> two
> > releases.
> > Traian
> >> Sent: Friday, November 23, 2007 11:00 AM
> provider
> >> Depends shows that in FDOCOMMON.DLL ?Release at FdoIDisposable@@QAEHXZ
> is
> >> missing
> >> i have fdo2fdo with the same ogrprovider.dll , and it fdo2fdo
> connect
> >> without errors.
> >> So i must do something wrong.
> >> > It means it couldn't find the function CreateConnection() in the
> >> provider
> >> > dll. I don't remember whether I compiled the 3.2.2 OGR binary with
> VS
> >> SP1
> >> > or not and whether that would make a difference. It's worth it to
> use
> >> > depends.exe to check if the provider is missing any dependencies.
> >> > Traian
> >> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
> >> > Sent: Friday, November 23, 2007 10:00 AM
> >> > To: FDO Users Mail List
> >> provider
> >> > Can you send me the app? I will try it and see what I find.
> >> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno
> Scott
> >> > Sent: Friday, November 23, 2007 5:34 AM
> >> > Subject: [fdo-users] Problem with C++ application with OGR
> provider
> >> > I have a small MFC C++ application builded with Visual studio 2005
> >> > I successfully use it with all osgeo provider ecept for OGR
> >> > I compile against the fdo 3.2.2 binaries and i use the ogr
> provider
> >> 3.2.2
> >> > binary
> >> > As soon as a try to connect to the ogr provider
> >> >     FdoPtr<FdoIConnection>             connectionPtr;
> >> >     static IConnectionManager*         pConnectionManager
> >> > NULL;
> >> >     pConnectionManager =
> >> FdoFeatureAccessManager::GetConnectionManager();
> >> >     connectionPtr =
> >> > pConnectionManager->CreateConnection(_T("OSGEO.OGR.3.2.2"));
> >> > I got this message in visual studio
> >> >     'FDLWizard.exe': Loaded OGRProvider.dll', No symbols loaded.
> >> >     First-chance exception at 0x76df3baf in FDLWizard.exe:
> >> 0xC0000139:
> >> > Entry
> >> > Point Not Found.
> >> >     'FDLWizard.exe': Unloaded OGRProvider.dll'
> >> > And it finnaly throw an exception
> >> >     Unable to load the FDO Provider: The specified procedure could
> >> not be
> >> > found.
> >> > Someone has a idea?
> >> > Bruno
> >> > View this message in context:
> >> > http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-
> >> provider-tf4860799s18162.html#a13909997
> >> > Sent from the fdo-users mailing list archive at Nabble.com.
> >> > _______________________________________________
> >> > http://lists.osgeo.org/mailman/listinfo/fdo-users
> >> View this message in context: http://www.nabble.com/Problem-with-
> >> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13914578
> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915066
More information about the fdo-users mailing list
