[fdo-users] Problem with C++ application with OGR provider
Bruno Scott bscott at geomapgis.com
Fri Nov 23 12:24:21 EST 2007
I comfirm there is something wrong in the 3.2.2 binaries
I have re-downloaded these two files from
http://fdo.osgeo.org/downloads.html
OGRProvider-3.2.2.win32.zip
fdosdk-3.2.2_win32_release.tar.gz
Rebuild the app with them
and i got the error message.
Either it's the fdo or the ogr i can't tell
Bruno
Bruno Scott wrote:
> Got it working.
> i've downloaded the 3.2.1 FDO binaries + OGR 3.2.1 and it works
> Even if my app is compiled with the 3.2.2 FDO library
> There must be something wrong with the 3.2.2 binaries
> i am pretty sure to have compile everything with that 3.2.2 versions and
> use ogr version 3.2.2
> i will double check and tell you
> Thanks
> Traian Stanev wrote:
>> That explains why it works with fdo2fdo.
>> Traian
>>> -----Original Message-----
>>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>>> bounces at lists.osgeo.org] On Behalf Of Bruno Scott
>>> Sent: Friday, November 23, 2007 11:59 AM
>>> To: fdo-users at lists.osgeo.org
>>> Subject: RE: [fdo-users] Problem with C++ application with OGR provider
>>> fdo2fdo uses its own fdo dll, they have version 3.2.0.0
>>> > Does your fdo2fdo use an FDO.dll that is local to its exe directory?
>>> What
>>> > version is that dll if it exists?
>>> > Traian
>>> >> Sent: Friday, November 23, 2007 11:26 AM
>>> provider
>>> >> i used ListDlls.exe to show what dlls are loaded with by my apps and
>>> it
>>> >> shows
>>> >> the good directory.
>>> >> In this directory all fdo dlls are have version 3.2.2.65
>>> >> except for xalan,xercess and gdal of course, that are not fdo dlls.
>>> >> OGRProvider.dll does not show any file version :(
>>> >> > Looks like some of your dlls are 3.2.1 and others are 3.2.2.
>>> >> > The signature of FdoIDisposable::Release was changed between those
>>> >> two
>>> >> > releases.
>>> >> > Traian
>>> >> >> Sent: Friday, November 23, 2007 11:00 AM
>>> >> provider
>>> >> >> Depends shows that in FDOCOMMON.DLL
>>> ?Release at FdoIDisposable@@QAEHXZ
>>> >> is
>>> >> >> missing
>>> >> >> i have fdo2fdo with the same ogrprovider.dll , and it fdo2fdo
>>> >> connect
>>> >> >> without errors.
>>> >> >> So i must do something wrong.
>>> >> >> > It means it couldn't find the function CreateConnection() in
>>> the
>>> >> >> provider
>>> >> >> > dll. I don't remember whether I compiled the 3.2.2 OGR binary
>>> with
>>> >> VS
>>> >> >> SP1
>>> >> >> > or not and whether that would make a difference. It's worth it
>>> to
>>> >> use
>>> >> >> > depends.exe to check if the provider is missing any
>>> dependencies.
>>> >> >> > Traian
>>> >> >> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg
>>> Boone
>>> >> >> > Sent: Friday, November 23, 2007 10:00 AM
>>> >> >> > To: FDO Users Mail List
>>> >> >> provider
>>> >> >> > Can you send me the app? I will try it and see what I find.
>>> >> >> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno
>>> >> Scott
>>> >> >> > Sent: Friday, November 23, 2007 5:34 AM
>>> >> >> > Subject: [fdo-users] Problem with C++ application with OGR
>>> >> provider
>>> >> >> > I have a small MFC C++ application builded with Visual studio
>>> 2005
>>> >> >> > I successfully use it with all osgeo provider ecept for OGR
>>> >> >> > I compile against the fdo 3.2.2 binaries and i use the ogr
>>> >> provider
>>> >> >> 3.2.2
>>> >> >> > binary
>>> >> >> > As soon as a try to connect to the ogr provider
>>> >> >> >     FdoPtr<FdoIConnection>             connectionPtr;
>>> >> >> >     static IConnectionManager*         pConnectionManager
>>> >> >> > NULL;
>>> >> >> >     pConnectionManager =
>>> >> >> FdoFeatureAccessManager::GetConnectionManager();
>>> >> >> >     connectionPtr =
>>> >> >> > pConnectionManager->CreateConnection(_T("OSGEO.OGR.3.2.2"));
>>> >> >> > I got this message in visual studio
>>> >> >> >     'FDLWizard.exe': Loaded OGRProvider.dll', No symbols
>>> loaded.
>>> >> >> >     First-chance exception at 0x76df3baf in FDLWizard.exe:
>>> >> >> 0xC0000139:
>>> >> >> > Entry
>>> >> >> > Point Not Found.
>>> >> >> >     'FDLWizard.exe': Unloaded OGRProvider.dll'
>>> >> >> > And it finnaly throw an exception
>>> >> >> >     Unable to load the FDO Provider: The specified procedure
>>> could
>>> >> >> not be
>>> >> >> > found.
>>> >> >> > Someone has a idea?
>>> >> >> > Bruno
>>> >> >> > View this message in context:
>>> >> >> > http://www.nabble.com/Problem-with-C%2B%2B-application-with-
>>> OGR-
>>> >> >> provider-tf4860799s18162.html#a13909997
>>> >> >> > Sent from the fdo-users mailing list archive at Nabble.com.
>>> >> >> > _______________________________________________
>>> >> >> > http://lists.osgeo.org/mailman/listinfo/fdo-users
>>> >> >> View this message in context: http://www.nabble.com/Problem-with-
>>> >> >> C%2B%2B-application-with-OGR-provider-
>>> tf4860799s18162.html#a13914578
>>> >> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915066
>>> C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915245
View this message in context: http://www.nabble.com/Problem-with-C%2B%2B-application-with-OGR-provider-tf4860799s18162.html#a13915824
More information about the fdo-users mailing list
