[fdo-users] Improving performance for NEN1878 provider, howto?
Piet Bibber piet.bibber at gmail.com
Mon Oct 1 10:15:43 EDT 2007
Robert, Badreddine, Gavin
I do provide the extends and counts in Nen1878OptimizedAggregateReader. Is
that what you refer to?
Piet
On 10/1/07, Robert Fortin <robert.fortin at autodesk.com> wrote:
> Badreddine,
> Isn't it the combination of count and spatialExtents that need to be
> optimized?
> I believe Map looks for the equivalent of
> Select SpatialExtents(geometry), count(*)  from <class>
> RF
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Badreddine
> Karoui
> Sent: Monday, October 01, 2007 9:42 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] Improving performance for NEN1878 provider,
> howto?
> Hi,
> You may want to implement the FdoISelectAggregates command plus the
> SpatialExtents and Count functions. If these two functions are not
> implemented, then Map will scan all the geometries to find the minimum
> bounding rectangle of all the data.
> Badreddine
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Piet Bibber
> Sent: Monday, October 01, 2007 7:46 AM
> Subject: [fdo-users] Improving performance for NEN1878 provider, howto?
> Hello,
> My NEN1878 provider is almost done, but performance is not so fantastic
> when
> reading the geometry; reading the schema is alright.
> That is stange, as I cache in the geometry when I read the schema
> (NEN1878
> schema discovery requires a full file scan; no seperate schema header).
> (The
> schema is read within 3 seconds for a 2.3MB file, including the geometry
> and
> attributes (all in memory (using STL)).
> The SDF and SHP all seem so fast :-)
> Map 3D seem to spend most of his time caching in the geometry (see
> source
> code below)
> I based my provider on the SHP provider, the reader seem to use
> FDO_READER
> template, but I can't find where that points to. Maybe there are better
> optimized readers.
> Thanks.
> Piet
> Excerpt from the source files:
>    FdoByteArray * CreateCachedGeometry(FdoByteArray* fgfByteArray_I)
>        FdoByteArray*   fgfByteArray = fgfByteArray_I; // it may be
> reallocated
>        int             count = mFeature->GetNumPoints();
>        FdoInt32        numPointOrds = 2;
>        FdoInt32        numBytesForOrdinates = numPointOrds *
> sizeof(double)
> * count;
>        FdoInt32        numParts = 0;
>        FdoGeometryType fdoGeomType  = GetFdoGeometryType();
>        FdoInt32        dimensionality = FdoDimensionality_XY;
>        FdoInt32        numPositions   = mFeature->GetNumPoints();
>        fgfByteArray->Clear();
>        fgfByteArray = FdoByteArray::Append(fgfByteArray,
> sizeof(fdoGeomType), (FdoByte *) &fdoGeomType);
>        switch (fdoGeomType)
>        case FdoGeometryType_None:
>            break;
>            case FdoGeometryType_Point:
> sizeof(dimensionality), (FdoByte*)&dimensionality);
> numBytesForOrdinates,   (FdoByte*)mFeature->GetPoints());
>                    break;
>            case FdoGeometryType_LineString:
> sizeof(dimensionality), (FdoByte *) &dimensionality);
> sizeof(count),
> (FdoByte *)&count);
> numBytesForOrdinates, (FdoByte *)mFeature->GetPoints());
>                    break;
>            default:
>            throw
> FdoException::Create(FdoException::NLSGetMessage(FDO_NLSID(FDO_10_UNSUPP
> ORTEDGEOMETRYTYPE)));
>            return (fgfByteArray);
> // Returns pointer to vector of DoublePoints
> inline DoublePoint* Nen1878Feature::GetPoints()
>    return (&mCoordinates[0]);
> http://www.nabble.com/Improving-performance-for-NEN1878-provider%2C-howt
> o--tf4547817s18162.html#a12977669
> Sent from the fdo-users mailing list archive at Nabble.com.
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20071001/2d8d831d/attachment.html
More information about the fdo-users mailing list
