[fdo-users] FdoMessage.h missing from svn?
Greg Boone greg.boone at autodesk.com
Wed Oct 10 11:13:18 EDT 2007
I believe you will have to build the FDO API before building the PostGIS
provider. PostGIS cannot be built off of the FDO SDK files.
Follow the instructions in OpenSourceBuild__README.txt on how to build
FDO.
Here is a quick step by step set of calls for a debug release:
1) Call setenvironment.bat
2) Call build_thirdparty -w=fdo -c=debug
3) Call build -w=fdo -c=debug
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of John Pulles
Sent: Wednesday, October 10, 2007 10:56 AM
To: FDO Users Mail List
Subject: [fdo-users] FdoMessage.h missing from svn?
Hi list,
I'm trying to build fdo postgis from the subversion code tree, but am
running into problems. It seems that the FdoMessage.h file is missing
from the repository; it is referenced in
https://svn.osgeo.org/fdo/trunk/Fdo/Unmanaged/Inc/Common/Exception.h but
not present anywhere.
In a source archive this file can be found in the Fdo\Unmanaged\Inc
folder, so it probably needs to be added to the repository.
Kind regards,
John
John Pulles
Geodan IT b.v.
Buitenhaven 27-A
5211TP 's-Hertogenbosch
Tel: +31 (0)73 - 692 5151
Fax: +31 (0)73 - 692 5150
Postadres / mailing address
President Kennedylaan 1
1079MB Amsterdam
E-mail:  john.pulles at geodan.nl
Website: http://www.geodan.nl
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
