[fdo-users] FdoMessage.h missing from svn?
Greg Boone greg.boone at autodesk.com
Mon Oct 15 20:18:45 EDT 2007
Have you solved this? I recommend a full clean-rebuild to try and solve
it. Make sure you have taken all the files from the FDO SVN.
Greg
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of John Pulles
Sent: Thursday, October 11, 2007 10:47 AM
To: FDO Users Mail List
Subject: Re: [fdo-users] FdoMessage.h missing from svn?
Greg Boone schreef:
> I believe you will have to build the FDO API before building the
> provider. PostGIS cannot be built off of the FDO SDK files.
> Follow the instructions in OpenSourceBuild__README.txt on how to build
> FDO.
> Here is a quick step by step set of calls for a debug release:
> 1) Call setenvironment.bat
> 2) Call build_thirdparty -w=fdo -c=debug
Thanks Greg,
The "missing" file is indeed built on build_thirdparty.
> 3) Call build -w=fdo -c=debug
I think I have followed the README document, but am getting the
following error on the MgCommon subproject here:
    Target MgCommon:
        D:\Programs\Microsoft Visual Studio
8\Common7\IDE\..\..\vc\vcpackages\vc
build.exe E:\fdo\Fdo\Managed\Project\MgCommon.tmp_Debug_Win32.vcproj
"Debug|Win3
2"
        Project : error PRJ0019: A tool returned an error code from
"Updating As
sembly Version Information for ..\Bin\Win32\Debug\OSGeo.FDO.Common.dll"
    Done building target "MgCommon" in project "FDO.sln" -- FAILED.
Is this familiar to anyone?
Regards,
John.
> From: fdo-users-bounces at lists.osgeo.org
> Sent: Wednesday, October 10, 2007 10:56 AM
> Subject: [fdo-users] FdoMessage.h missing from svn?
> Hi list,
> I'm trying to build fdo postgis from the subversion code tree, but am
> running into problems. It seems that the FdoMessage.h file is missing
> from the repository; it is referenced in
> https://svn.osgeo.org/fdo/trunk/Fdo/Unmanaged/Inc/Common/Exception.h
but
> not present anywhere.
> In a source archive this file can be found in the Fdo\Unmanaged\Inc
> folder, so it probably needs to be added to the repository.
> Kind regards,
> John
John Pulles
Geodan IT b.v.
Buitenhaven 27-A
5211TP 's-Hertogenbosch
Tel: +31 (0)73 - 692 5151
Fax: +31 (0)73 - 692 5150
Postadres / mailing address
President Kennedylaan 1
1079MB Amsterdam
E-mail:  john.pulles at geodan.nl
Website: http://www.geodan.nl
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
