[fdo-users] Writing managed provider - HowTo
Orest Halustchak orest.halustchak at autodesk.com
Thu Oct 18 09:50:03 EDT 2007
Hi Maksim,
In this case, you'll also run into problems from Map and MapGuide access
because they both include unmanaged references to the FDO api.
Yes, Map currently does not support all capabilities from FDO - these
are works in progress.
Thanks,
Orest.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Maksim Sestic
Sent: Wednesday, October 17, 2007 10:29 AM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] Writing managed provider - HowTo
Hi Orest,
I was thinking of using .NET. I'll explain my intentions a bit more in
detail... it's actually about writing FDO provider for Autodesk DWG. I
already did something similar using my own meta-model, but "porting" it
to
FDO would be, I guess, interesting thing to see. Autodesk Map 3D
currently
lacks support for certain FDO types (e.g. associations, object data
properties) which is truly pitty since DWG, as it is, makes the whole
thing
doable.
It's also very challenging at the same time, since I cannot rely on DWG
only
as a container to entities. Mechanism should be able to support Cloning
and
DeepCloning opreations, even to and from different databases (DWGs),
just as
AutoCAD originally does.
Regards,
Maksim Sestic
Orest Halustchak wrote:
> Hi Maksim,
> This is something that's not quite supported yet by FDO, all providers
> so far are unmanaged. We had discussed support of managed providers
> initially, but haven't built in complete support for this yet.
> Are you thinking of using .Net or Java?
> Thanks,
> Orest.
View this message in context:
http://www.nabble.com/Writing-managed-provider---HowTo-tf4640210s18162.h
tml#a13254821
Sent from the fdo-users mailing list archive at Nabble.com.
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
