[fdo-users] FdoMessage.h missing from svn?
Dan Stoica dan.stoica at autodesk.com
Tue Oct 23 14:42:40 EDT 2007
Ah!  Is FDOTHIRDPARTY set correctly?
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
Sent: Tuesday, October 23, 2007 2:41 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] FdoMessage.h missing from svn?
These error messages are coming from the pre-build event (see the
project's settings):
$(FDOTHIRDPARTY)\util\UpdateVersion\bin\UpdateVersion.exe -b BuildDay -r
Fixed -i ..\Src\OSGeo\Common\AssemblyVersion.cpp -o
Somebody more familiar than me with UpdateVersion.exe maybe can help?
Also the post-build event can be a problem...
Dan.
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Greg Boone
Sent: Tuesday, October 23, 2007 2:12 PM
I have no idea what the problem might be...
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of John Pulles
Sent: Tuesday, October 23, 2007 11:00 AM
Subject: Re: [fdo-users] FdoMessage.h missing from svn?
Greg Boone schreef:
Have you solved this? I recommend a full clean-rebuild to try and solve
it. Make sure you have taken all the files from the FDO SVN.
Hi Greg,
Thanks for your reaction. I've tried to rebuild in a clean environment
by still get the following error for the Managed FDO part:
Updating Assembly Version Information for
..\Bin\Win32\Debug\OSGeo.FDO.Common.dll
Error reading input.
System.ArgumentException: File does not exist.
Parameter name: filename
   at MattGriffith.UpdateVersion.RunUpdateVersion.ReadFile(String
filename)
   at MattGriffith.UpdateVersion.RunUpdateVersion.GetInput(Options
options)
   at MattGriffith.UpdateVersion.RunUpdateVersion.Main(String[] args)
Project : error PRJ0019: A tool returned an error code from "Updating
..\Bin\Win32\Debug\OSGeo.FDO.Common.dll"
No idea what it comes from (it seems the FDO\Managed\Project's are not
being build), but it's fairly blocking to make a debug version.
Kind regards,
John
Greg
-----Original Message-----
Sent: Thursday, October 11, 2007 10:47 AM
Greg Boone schreef:
	I believe you will have to build the FDO API before building the
	provider. PostGIS cannot be built off of the FDO SDK files.
	Follow the instructions in OpenSourceBuild__README.txt on how to
build
	FDO.
	Here is a quick step by step set of calls for a debug release:
	1) Call setenvironment.bat
	2) Call build_thirdparty -w=fdo -c=debug
Thanks Greg,
The "missing" file is indeed built on build_thirdparty.
	3) Call build -w=fdo -c=debug
I think I have followed the README document, but am getting the
following error on the MgCommon subproject here:
    Target MgCommon:
        D:\Programs\Microsoft Visual Studio
8\Common7\IDE\..\..\vc\vcpackages\vc
build.exe E:\fdo\Fdo\Managed\Project\MgCommon.tmp_Debug_Win32.vcproj
"Debug|Win3
2"
"Updating As
sembly Version Information for ..\Bin\Win32\Debug\OSGeo.FDO.Common.dll"
    Done building target "MgCommon" in project "FDO.sln" -- FAILED.
Is this familiar to anyone?
Regards,
John.
Pulles
	Sent: Wednesday, October 10, 2007 10:56 AM
	Subject: [fdo-users] FdoMessage.h missing from svn?
	Hi list,
	I'm trying to build fdo postgis from the subversion code tree,
but am
	running into problems. It seems that the FdoMessage.h file is
missing
	from the repository; it is referenced in
https://svn.osgeo.org/fdo/trunk/Fdo/Unmanaged/Inc/Common/Exception.h
but
	not present anywhere.
	In a source archive this file can be found in the
Fdo\Unmanaged\Inc
	folder, so it probably needs to be added to the repository.
	Kind regards,
	John
John Pulles
Geodan IT b.v.
Buitenhaven 27-A
5211TP 's-Hertogenbosch
Tel: +31 (0)73 - 692 5151
Fax: +31 (0)73 - 692 5150
Postadres / mailing address
President Kennedylaan 1
1079MB Amsterdam
E-mail:  john.pulles at geodan.nl
Website: http://www.geodan.nl
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20071023/6e0ee8d7/attachment-0001.html
More information about the fdo-users mailing list
