[fdo-users] RE: Unable to test PostGis provider
Jason Birch Jason.Birch at nanaimo.ca
Tue Sep 11 11:50:37 EDT 2007
On the server machine, you need to have the postgresql/bin directory in the system path (makse sure not in user path), first in the path is probably safest.  Others have found that sometimes you have to move specific DLLs from that directory into the fdo/bin directory, but I haven't had to do that myself.
Depending on the version of the provider that you have downloaded, you may also need to install the MSVC++ 2005 SP1 Runtime, available from the Microsoft site.
Jason
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Maciej Skorczewski
Sent: Tuesday, September 11, 2007 03:21
To: FDO Users Mail List
Subject: Re: [fdo-users] RE: Unable to test PostGis provider
Hi Jason !
I use postgis on my develop machine...it works fine...but after move aplication to serwer i can't connect to Postgis by PostGis provider - can't see any  any editable connection properties.
and get error: "Failed to load connection control for provider. Either the provider is not installed, or there was an error accessing it"
So what is wrong whit this...Postgis provider i better as Ogr...i can make more things whit this...but when i need it it don't work. :(
ps. i try copy FDO frolder from develop machine to server but still nothing.
I use MG 1.2 Beta
OS: XP+ apache+php
Jason Birch pisze:
 > Hi,
 > Great to hear you are trying out the PostGIS provider.
Maciej Skórczewski
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
