[fdo-users] fdo for autocad connection to arcsde 45 character limitation
Landwehr, Jim JLandwehr at waukeshacounty.gov
Wed Apr 16 16:19:03 EDT 2008
Hello,
We are encountering an exception error when we try and connect to our ESRI SDE database (SQL Server) using AutoCad Map 2008, which I'm told uses the Open source FDO developed here. We have found on the autodesk forums that there evidently is a 45 character limitation on features using a connection. Does anyone know if this is going to be addressed by the arcsde fdo developer? The 45 character issue is NOT an ESRI limitation, and is prohibiting our autodesk users from connecting to our new database.
The autodesk forum thread is found (near the bottom, from bleestein) at;
http://discussion.autodesk.com/thread.jspa?messageID=5699330
Any help or insight appreciated.
Jim
James Landwehr, GISP
LIS Analyst
Waukesha County Parks and Land Use
262-548-7946
jlandwehr at waukeshacounty.gov
http://www.waukeshacounty.gov/landandparks
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20080416/4169b739/attachment.html
More information about the fdo-users mailing list
