[fdo-users] coordinate system bug?
Brad Nesom kidsmake6 at msn.com
Mon Apr 21 17:43:25 EDT 2008
Yes I have verified that the sdelayers have the correct coordinate definition. However it was just explained to me by esri that the srid in sde is a moving target. each time sde finds any variation (not sure why it htinks there is any variation) it creates a new srid value (random) and assigns the description see below.  From esri support >>>3. As we discussed, the 3rd party software maybe should read the auth_srid to get the Oracle spatial coordinate system definition. But in general cases, if a layer is not from Oracle spatial, there may not be the auth_id value. ESRI's ID (comparable to Oracle's SRID)http://arcweb.esri.com/arcwebonline/services/pcs_alpha.htmNAD_1983_StatePlane_Oklahoma_North_FIPS_3501  32124    Oracle Database 10g Release 10.2.0.3.0 - ProductionSQL> select distinct SRID from sde.spatial_references;      SRID----------         1         2         3         4         5         6         7         8         9        10        11      SRID----------        12        13        14        15        16        17        18        19        20        21        22      SRID----------        23        24        25        26        27        28        29        30        31        32        33      SRID----------        34        35        36        37        38        39        40        41        42        43        44      SRID----------        45        46        47        48        49        50        51        52        53        54        55      SRID----------        56        57        58        59        60        61        62        63        64        65        66      SRID----------        67        68        69        70        71        72        73        74        75        76        77      SRID----------        78        79        80        81        82        83        84        85        86        87        88      SRID----------        89        90        91        92        93        94        95        96        97        98        99      SRID----------       100       101       102       103       104       105       106       107       108       109       110      SRID----------       111       112       113       114       115       116       117       118       119       120       121      SRID----------       122       123       124       125       126       127       128       129       130       131       132      SRID----------       133       134       135       136       137       138       139       140       141       142       143      SRID----------       144       145       146       147       148       149       150       151       152       153       154      SRID----------       155       156       157       158       159       160       161       162       163       164       165      SRID----------       166       167       168       169       170       171       172       173       174       175       176      SRID----------       177       178       179       180       181       182       183       184       185       186       187      SRID----------       188       189       190       191       192       193       194       195       196       197       198      SRID----------       199       200       201       202       203       204       205       206       207       208       209      SRID----------       210       211       212       213       214       215       216       217       218       219       220      SRID----------       221       222       223       224       225       226       227       228       229       230       231      SRID----------       232       233       234       235       236       237       238       239       240       241       242      SRID----------       243       244       245       246       247       248       249       250       251       252       253      SRID----------       254       255       256       257       258       259       260       261       262       263       264      SRID----------       265       266       267267 rows selected.SQL> select description, auth_srid, SRTEXT from sde.spatial_references where SRID in (86, 180, 133);DESCRIPTION                                                       AUTH_SRID---------------------------------------------------------------- ----------SRTEXT--------------------------------------------------------------------------------        41106PROJCS["NAD_1983_StatePlane_Oklahoma_North_FIPS_3501_Feet",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1968500.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-98.0],PARAMETER["Standard_Parallel_1",35.56666666666667],PARAMETER["Standard_Parallel_2",36.76666666666667],PARAMETER["Latitude_Of_Origin",35.0],UNIT["Foot_US",0.3048006096012192]]DESCRIPTION                                                       AUTH_SRID---------------------------------------------------------------- ----------SRTEXT--------------------------------------------------------------------------------UNKNOWNUNKNOWNSQL>
From: orest.halustchak at autodesk.comTo: fdo-users at lists.osgeo.orgDate: Mon, 21 Apr 2008 14:25:41 -0700Subject: RE: [fdo-users] coordinate system bug?
Hi Brad,
The provider gets the coordinate system information from SDE. It doesn’t go directly against the Oracle metadata in this case and is independent of whether the server is Oracle, SQL Server, etc. It uses whatever the SDE api returns as the coord sys wkt. Map 2008 and 2009 include the ability to recognize either Oracle or ESRI variations of the wkt value, so it’s unclear why some of these cases end up not being recognized. I assumed that you verified that the sde layer definitions all use the identical coordinate system definition?
Thanks,
Orest.
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad NesomSent: Monday, April 21, 2008 9:50 AMTo: FDO Users Mail ListSubject: [fdo-users] coordinate system bug?
 I have been working on a problem with esri for quite some time. I have an oracle database storing my ArcSDE data as SDO geometry (supported on oracle 10g 2.3 and arcsde 9.2). I use several parameters in my keyword to load the data and only use esri to load. The significant parameters to this issue are the srid and the geometry type being 41106 and sdo_geometry respectively. After having scaling problems other problems with displaying units in arcmap for over 2 years esri finally blamed the problem on a bug in oracle (they would give me the bug number). Stating that the oracle wkt is not an international standard and thus has problems being recognised in the esri software. The wkt 41106 is exactly the same as the esri system NAD 1983 StatePlane Oklahoma North FIPS 3501 (Feet).prj with the exception of the name (Oklahoma 3501, Northern Zone (1983, US Survey feet))(which by the way is the same as the autodesk ok83-nf with no problems there). ESRI said this was the cause of the oracle bug. I know that sde is having a problem relating this wkt because if I build a feature dataset and assign the esri system to it, then load the data into that dataset (in esri products the dataset determines the coordinate system of all feature classes contained within), It assigns the wkt to the feature class until you go and reassign the esri system to the feature dataset (this is the workaround esri provided). All is well until something like a load, truncate or new feature class is added to the dataset.Now my question.In map 3d 2008 or 2009, when I get connected via FDO the list of coordinate systems is inconsistent (see attached jpg sdelistinmap.jpg). If I look at my oracle metadata all srids are assigned the 41106. Where does map pull the coordinate system information for the arcsde fdo data type? is it from the sde layer definition? Any help or understanding would be grand.     select * from mdsys.cs_srs where srid = 41106/-------------------------------------------------------------------------------CS_BOUNDS(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z), SDO_ELEM_INFO, SDO_ORDINATES-------------------------------------------------------------------------------PROJCS["Oklahoma 3501, Northern Zone (1983, US Survey feet)", GEOGCS ["NAD 83 (ontinental US)", DATUM ["NAD 83 (Continental US)", SPHEROID ["GRS 80", 6378137,298.257222101]], PRIMEM [ "Greenwich", 0.000000 ], UNIT ["Decimal Degree", 0.01CS_NAME        SRID-------------------------------------------------------------------- ---------- AUTH_SRID----------AUTH_NAME-------------------------------------------------------------------------------WKTEXT-------------------------------------------------------------------------------CS_BOUNDS(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z), SDO_ELEM_INFO, SDO_ORDINATES-------------------------------------------------------------------------------45329251994330]], PROJECTION ["Lambert Conformal Conic"], PARAMETER ["Standard_arallel_1", 35.566667], PARAMETER ["Standard_Parallel_2", 36.766667], PARAMETER["Central_Meridian", -98.000000], PARAMETER ["Latitude_Of_Origin", 35.000000], CS_NAME        SRID-------------------------------------------------------------------- ---------- AUTH_SRID----------AUTH_NAME-------------------------------------------------------------------------------WKTEXT-------------------------------------------------------------------------------CS_BOUNDS(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z), SDO_ELEM_INFO, SDO_ORDINATES-------------------------------------------------------------------------------ARAMETER ["False_Easting",   1968500.0000], UNIT ["U.S. Foot", 0.3048006096012]
More immediate than e-mail? Get instant access with Windows Live Messenger.
_________________________________________________________________
Pack up or back up–use SkyDrive to transfer files or keep extra copies. Learn how.
http://www.windowslive.com/skydrive/overview.html?ocid=TXT_TAGLM_WL_Refresh_skydrive_packup_042008
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20080421/4caac43c/attachment-0001.html
More information about the fdo-users mailing list
