[fdo-users] Accessing Attributes from Shapefile
surrounded rob.sosnowski at itd.idaho.gov
Wed Aug 20 20:22:56 EDT 2008
Thanks for the links.
This is resolved - had some confusion over the DefaultFileLocation.  At any
rate, sample code similar to what I used can be found within:
http://www.nabble.com/SHP-modifications-issue-td8386605.html#a8525978
surrounded wrote:
> Hello all,
> New to FDO, using it within C#.net web service - trying to do the
> following:
> -	Query a shapefile with an x, y coordinate (latitude, longitude),
> returning the shapefile attributes that exist at the supplied
> coordinate.
> Currently, I've been able to create a connection using
> FeatureAccessManager and IConnection.  I'm not sure how to proceed
> further.  Suggestions?? If available, code examples would be much
> appreciated.
> Thanks....Rob
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/Accessing-Attributes-from-Shapefile-tp19070567p19080482.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
