[fdo-users] FDO for sde personal
Brad Nesom kidsmake6 at msn.com
Tue Aug 26 13:28:32 EDT 2008
I wonder what the connection string would look like and how would you get it
to interface with the Map 2009 interface? If you could make a programmatic
connection and get that to persist in the user interface?
Brad
This just in from esri...
Workgroup ArcSDE is not, strictly speaking, ArcSDE. It does not
have a giomgr service process (all connections must be through
Direct Connect), and command-line tools are not supported.
You can try to use an appropriate Direct Connect connection
string in third-party applications, but this is not supported.
- V
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Tony
Sent: Monday, August 25, 2008 9:29 PM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] FDO for sde personal
yes SDE personal is not the SDE enterprise
SDE enterprise does have the instant running on 5151 port but SDE personal
does this connection using direct connect but its ESRI technology . i have
used OGR for personal geodatbase i know OGR can be used for personal
geodabase but dont know how
tony
Brad Nesom wrote:
> Tony,
> Did you have any luck? I am trying to do same and can't get the connection
> string. Perhaps because sde workgroup is not running a real sde process
> the
> arcsde provider doesn't use the same library.
> Any idea what port sde workgroup uses? 5151 is not doing the trick.
> Brad
> From: fdo-users-bounces at lists.osgeo.org
> Sent: Monday, August 25, 2008 12:39 AM
> Subject: [fdo-users] FDO for sde personal
> Is there any FDO we can use for SDE personal ( SQL server express)
> http://n2.nabble.com/FDO-for-sde-personal-tp780698p780698.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
http://n2.nabble.com/FDO-for-sde-personal-tp780698p783044.html
More information about the fdo-users mailing list
