[fdo-users] Batch Insert using Insert Command
wkhattak Wajid.Khattak at keynetix.com
Mon Jul 14 04:07:19 EDT 2008
I am trying to figure out if Autodesk's SQL Provider could be used for a
batch insert while creating a Feature Class instead of executing the
Insert.Execute() in a loop?Like is it possible to make use of
BatchParameterValues within the Insert command?
regards,
View this message in context: http://www.nabble.com/Batch-Insert-using-Insert-Command-tp18439234p18439234.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
