[fdo-users] postgis and performance
Zac Spitzer zac.spitzer at gmail.com
Mon Jul 28 03:11:30 EDT 2008
On Mon, Jul 28, 2008 at 5:07 PM, alucas <alucas at srtec.com> wrote:
> Hi zac,
> But... Views are more slowly than tables. The best choice would be to change
> the provider to avoid this string matching.
views are pretty much zero cost, especially when compared to the
string matching,
which I completely agree with you on,
but for instant gratification(tm) views will do it for you
> Regards.
> zspitzer wrote:
>> For better performance, try using views on your tables which only
>> expose the minimal
>> set of columns you require.
>> Mapguide does "select * from table" which slows things down a lot,
>> because each column
>> is accessed via name rather than index and that's a lot of string
>> matching..
>> http://trac.osgeo.org/mapguide/ticket/272
>> i.e. with a 500k row table, each additional column is now involved in
>> another 500k of string matches
>> Regards
>> Zac
>> On Sat, Jul 26, 2008 at 1:09 AM, alucas <alucas at srtec.com> wrote:
>>> Hello List,
>>> I'm testing postgis to store some Gregraphic layers and publish this data
>>> to
>>> the internet via Mapguide Enterprise 2009. I've performance problems to
>>> publish some large volumes of vector data. For example, mapguide can't
>>> preview (with Autodesk Mapguide Studio) one layer with 140.000 records. I
>>> need to publish some layers with aprox 500.000 records
>>> So, I need to manage large volume data sets with postgis and mapguide and
>>> I've some questions:
>>> - In the unit tests for the postgis provider, what are the volumes of
>>> data
>>> tested?
>>> - I've loaded the data into postgis via shp2pgsql. I don't know if the
>>> default database created via shp2pgsql is the best for the postgis
>>> provider
>>> performance. It's possible to improve the database performance for
>>> example
>>> creating some gist indexes? If yes, how can I create the optimal index to
>>> achieve the best performance in queries?
>>> To summarize, I need some help for optimize my postgis datastore...
>>> Some useful information about the system:
>>> MGE 2009
>>> Autodesk Mapguide Studio 2009
>>> Postgis 8.2.9
>>> Postgis 1.3.3
>>> FDO provider for postgis: 3.3.0 (Downloaded from GeoMap web page)
>>> Thanks in advance.
>>> View this message in context:
>>> http://www.nabble.com/postgis-and-performance-tp18653591p18653591.html
>>> Sent from the FDO Users mailing list archive at Nabble.com.
>>> fdo-users mailing list
>>> fdo-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> Zac Spitzer -
>> http://zacster.blogspot.com (My Blog)
>> +61 405 847 168
> View this message in context: http://www.nabble.com/postgis-and-performance-tp18653591p18685149.html
Zac Spitzer -
+61 405 847 168
More information about the fdo-users mailing list
