[fdo-users] postgis and performance
alucas alucas at srtec.com
Mon Jul 28 03:52:16 EDT 2008
Hi Traian,
In this case, the user don't wants to change his spatial database system. We
need to achieve a performance similar to Oracle Spatial or MS Sql server
(even MySQL).
PD: Sorry for my english.
Thanks.
Traian Stanev wrote:
> Yes, to get best performance for this many features, consider publishing a
> snapshot of the data, exported to SDF or SHP format for example.
> Traian
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>> bounces at lists.osgeo.org] On Behalf Of alucas
>> Sent: Monday, July 28, 2008 3:08 AM
>> To: fdo-users at lists.osgeo.org
>> Subject: Re: [fdo-users] postgis and performance
>> Hi zac,
>> But... Views are more slowly than tables. The best choice would be to
>> change
>> the provider to avoid this string matching.
>> Regards.
>> zspitzer wrote:
>> > For better performance, try using views on your tables which only
>> > expose the minimal
>> > set of columns you require.
>> > Mapguide does "select * from table" which slows things down a lot,
>> > because each column
>> > is accessed via name rather than index and that's a lot of string
>> > matching..
>> > http://trac.osgeo.org/mapguide/ticket/272
>> > i.e. with a 500k row table, each additional column is now involved in
>> > another 500k of string matches
>> > Regards
>> > Zac
>> > On Sat, Jul 26, 2008 at 1:09 AM, alucas <alucas at srtec.com> wrote:
>> >> Hello List,
>> >> I'm testing postgis to store some Gregraphic layers and publish this
>> data
>> >> to
>> >> the internet via Mapguide Enterprise 2009. I've performance problems
>> to
>> >> publish some large volumes of vector data. For example, mapguide
>> can't
>> >> preview (with Autodesk Mapguide Studio) one layer with 140.000
>> records. I
>> >> need to publish some layers with aprox 500.000 records
>> >> So, I need to manage large volume data sets with postgis and
>> mapguide and
>> >> I've some questions:
>> >> - In the unit tests for the postgis provider, what are the volumes
>> of
>> >> data
>> >> tested?
>> >> - I've loaded the data into postgis via shp2pgsql. I don't know if
>> the
>> >> default database created via shp2pgsql is the best for the postgis
>> >> provider
>> >> performance. It's possible to improve the database performance for
>> >> example
>> >> creating some gist indexes? If yes, how can I create the optimal
>> index to
>> >> achieve the best performance in queries?
>> >> To summarize, I need some help for optimize my postgis datastore...
>> >> Some useful information about the system:
>> >> MGE 2009
>> >> Autodesk Mapguide Studio 2009
>> >> Postgis 8.2.9
>> >> Postgis 1.3.3
>> >> FDO provider for postgis: 3.3.0 (Downloaded from GeoMap web page)
>> >> Thanks in advance.
>> >> View this message in context:
>> >> http://www.nabble.com/postgis-and-performance-
>> tp18653591p18653591.html
>> >> Sent from the FDO Users mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> fdo-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> > Zac Spitzer -
>> > http://zacster.blogspot.com (My Blog)
>> > +61 405 847 168
>> View this message in context: http://www.nabble.com/postgis-and-
>> performance-tp18653591p18685149.html
View this message in context: http://www.nabble.com/postgis-and-performance-tp18653591p18685669.html
More information about the fdo-users mailing list
