[fdo-users] FDO doesn't compile on Debian Linux
Jack Lee jack.lee at autodesk.com
Tue Jul 29 18:36:30 EDT 2008
Is /usr/local/src/OpenSOurce_FDO the correct directory? Notice the second capital O in OpenSOurce_FDO?
make[2]: *** No rule to make target
'/usr/local/src/OpenSOurce_FDO/Utilities/Common/libProviderCommon.la',
needed by 'UnitTest'.  Stop.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of mike at malagatech.com
Sent: Tuesday, July 29, 2008 5:42 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] FDO doesn't compile on Debian Linux
I have downloaded version 3.3.1 of FDO to my Debian Linux system.  I'm
running the current stable distribution of Debian with the latest updates.
I believe I have installed of the required Debian packages to be able to
build and install FDO.  In addition to the base FDO source I also
downloaded the following providers: ArcSDE, GDAL, GenericRdbms, SHP.  I am
able to run "source setenvironment.sh" without an error.  I am able to run
"./build_thirdparty.sh" without an error.  When I try to run
"./build_linux.sh" or "./build_linux.sh --c release --a buildinstall --m
configure --w all" the process works for a while and then dies with the
error:
make[2]: Leaving directory
'/usr/local/src/OpenSource_FDO/Providers/GDAL/Src/UnitTest'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory
'/usr/local/src/OpenSource_FDO/Providers/GDAL/Src'
make: *** [install-recursive] Error 1
Any help would be appreciated,
Thank you,
Mike Juneau
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
