[fdo-users] [mapguide-users] FDO Toolbox
Jackie C. Ng jumpinjackie at gmail.com
Tue Jul 29 21:58:05 EDT 2008
Are you able to load an oracle connection?
ie. Create a file oracle.conn with the following content:
<?xml version="1.0"?>
<Connection>
    <Name>MyConnection</Name>
    <Provider>OSGeo.KingOracle.3.3</Provider>
    <ConnectionString>[Connection parameters]</ConnectionString>
</Connection>
and then right click the "Connections" node selecting oracle.conn
Email me if this doesn't work.
- Jackie
zspitzer wrote:
> I am using the 0.40 full bundle off the website
> On Tue, Jul 29, 2008 at 6:59 PM, Jackie C. Ng <jumpinjackie at gmail.com>
> wrote:
>> Are you using the trunk version or a previous release?
>> - Jackie
>> zspitzer wrote:
>>> Using connections - > new connection -> Custom
>>> I can connect to oracle but there's no node in the connection tree to
>>> click?
>>> z
>>> On Mon, Jul 28, 2008 at 3:35 PM, Jackie C. Ng <jumpinjackie at gmail.com>
>>> wrote:
>>>> Right click any connection node and there should be a "Save Connection"
>>>> menu
>>>> option.
>>>> - Jackie
>>>> zspitzer wrote:
>>>>> The tool looks great, I'm trying to create an oracle connection, but I
>>>>> can't find a save option
>>>>> for the new connection?
>>>>> z
>>>>> On Fri, Jul 25, 2008 at 10:35 PM, Jackie C. Ng
>>>>> wrote:
>>>>>> Hi Maksim,
>>>>>> No definite answer right now, but I'll just say that whatever is
>>>>>> implemented
>>>>>> in the FDO API will be (all eventually) exposed GUI-wise in FDO
>>>>>> Toolbox.
>>>>>> Best to file an enhancement issue on the matter.
>>>>>> - Jackie
>>>>>> Maksim Sestic wrote:
>>>>>>> Hi Jackie,
>>>>>>> Great job, thanks for sharing.
>>>>>>> Do you, by any chance, plan for FDO Toolbox to support schema/class
>>>>>>> attributes?
>>>>>>> Regards,
>>>>>>> Maksim Sestic
>>>>>>> -----Original Message-----
>>>>>>> From: fdo-users-bounces at lists.osgeo.org
>>>>>>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
>>>>>>> Sent: Wednesday, July 23, 2008 19:04
>>>>>>> To: fdo-users at lists.osgeo.org
>>>>>>> Subject: RE: [fdo-users] [mapguide-users] FDO Toolbox
>>>>>>> Hi Robert,
>>>>>>> Thanks for the comments. There's still lots of ideas I have, that
>>>>>>> have
>>>>>>> yet
>>>>>>> to materialse :-)
>>>>>>> Does GeometryType supercede GeometricType? Can/Does the
>>>>>>> GeometricPropertyDefintion accept both? I always have the two
>>>>>>> confused.
>>>>>>> - Jackie
>>>>>>> Robert Fortin wrote:
>>>>>>>> Jackie,
>>>>>>>> Great work indeed. Finally and admin tool for FDO!
>>>>>>>> I played a bit with it.  It got a me a bit of time to figure out
>>>>>>>> where
>>>>>>>> you could edit the schema (you have to go back to the connection to
>>>>>>>> find the popup).  But after that, it was straight forward. I like
>>>>>>>> the
>>>>>>>> fact that we finally have a spatial context editor.  I didn't spend
>>>>>>>> a
>>>>>>>> lot of time on it and will certainly do in the future.  A minor
>>>>>>>> detail
>>>>>>> the geometry type.
>>>>>>>> FDO has 2 ways to specify the geometry types for a geometry
>>>>>>>> property:
>>>>>>>> geometrictype and geometrytype.  GeometricType is what you are
>>>>>>>> using
>>>>>>>> and it is less specific or too vague.  We added GeometryType which
>>>>>>>> basically indicates the specific geometry type it support like
>>>>>>>> point,
>>>>>>>> multipoint, curve, etc.  I think that's what we need to show in the
>>>>>>>> UI
>>>>>>>> instead of the GeometricType.  As you can see, my comments are
>>>>>>>> pretty
>>>>>>> minor so far...
>>>>>>>> Thanks for doing this and making it available!
>>>>>>>> Robert
>>>>>>>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
>>>>>>>> Sent: Tuesday, July 22, 2008 11:34 AM
>>>>>>>> To: MapGuide Users Mail List; fdo-users at lists.osgeo.org
>>>>>>>> Cc: Sean Twomey
>>>>>>>> Subject: [fdo-users] RE: [mapguide-users] FDO Toolbox
>>>>>>>> HI Jackie,
>>>>>>>> It's a pretty cool tool.  I would have been happier if you and
>>>>>>>> Haris
>>>>>>>> could have collaborated on this, but I still haven't seen the
>>>>>>>> source
>>>>>>>> for fdo2fdo, so... :)
>>>>>>>> I was playing around with an earlier release a couple days ago and
>>>>>>>> found a few things that I would have liked to see, most of them
>>>>>>>> from
>>>>>>>> my experience with fdo2fdo.  I'll add them as enhancement requests
>>>>>>>> at
>>>>>>> Google Code.
>>>>>>>> Jason
>>>>>>>> From: Jackie Ng
>>>>>>>> Subject: [mapguide-users] FDO Toolbox
>>>>>>>> This is something that I have been working on in my spare time, and
>>>>>>>> now I think it is time to share it with you all.
>>>>>>>> FDO Toolbox is hosted on Google code:
>>>>>>>> http://code.google.com/p/fdotoolbox
>>>>>>>> _______________________________________________
>>>>>>>> fdo-users mailing list
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>>>>>>> http://themapguyde.blogspot.com
>>>>>>> http://www.linkedin.com/in/jackieng
>>>>>>> View this message in context:
>>>>>>> http://www.nabble.com/FDO-Toolbox-tp18591154p18615700.html
>>>>>>> Sent from the FDO Users mailing list archive at Nabble.com.
>>>>>>> __________ NOD32 3293 (20080723) Information __________
>>>>>>> This message was checked by NOD32 antivirus system.
>>>>>>> http://www.eset.com
>>>>>> http://www.nabble.com/FDO-Toolbox-tp18591154p18650866.html
>>>>> Zac Spitzer -
>>>>> http://zacster.blogspot.com (My Blog)
>>>>> +61 405 847 168
>>>> http://www.nabble.com/FDO-Toolbox-tp18591154p18684394.html
>>> Zac Spitzer -
>>> +61 405 847 168
>> http://www.nabble.com/FDO-Toolbox-tp18591154p18708026.html
> Zac Spitzer -
> +61 405 847 168
View this message in context: http://www.nabble.com/FDO-Toolbox-tp18591154p18724806.html
More information about the fdo-users mailing list
