[fdo-users] Does IApplySchema handle removed classes / removed properties?
Jackie C. Ng jumpinjackie at gmail.com
Tue Jul 29 21:59:27 EDT 2008
So I guess the question then becomes what is the FDO way to blow a cached
schema to smithereens (if any)? :-)
- Jackie
zspitzer wrote:
> It might be the effects of FDO schema caching?
> In Mapguide I just re-save the featuresource which blows away the cache
> On Tue, Jul 29, 2008 at 12:08 AM, Jackie C. Ng <jumpinjackie at gmail.com>
> wrote:
>> Hi All,
>> I am having trouble with the IApplySchema command with regards to
>> removing
>> classes and/or class properties.
>> After executing an IApplySchema on a modified schema, the schema shows
>> all
>> the signs of the class being removed, same applies for removed
>> properties.
>> But if were to execute an IDescribeSchema afterwards, the schema returned
>> from that command still has the class/property that was supposed to be
>> removed.
>> I wrote a test application to verify my findings.
>> TestDeletePropertyRaw()
>> http://code.google.com/p/fdotoolbox/source/browse/trunk/TestApp/TestApp.cs#35
>> TestDeleteClassRaw()
>> http://code.google.com/p/fdotoolbox/source/browse/trunk/TestApp/TestApp.cs#163
>> In both methods, the class/property is indicated as removed after the
>> IApplySchema executes, but then it reappears in the schema returned by
>> the
>> subsequent IDescribeSchema command.
>> Am I doing something wrong here?
>> - Jackie
>> http://themapguyde.blogspot.com
>> http://www.linkedin.com/in/jackieng
>> View this message in context:
>> http://www.nabble.com/Does-IApplySchema-handle-removed-classes---removed-properties--tp18689217p18689217.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
View this message in context: http://www.nabble.com/Does-IApplySchema-handle-removed-classes---removed-properties--tp18689217p18724819.html
More information about the fdo-users mailing list
