[fdo-users] FDO doesn't compile on Debian Linux
Jack Lee jack.lee at autodesk.com
Tue Jul 29 22:16:01 EDT 2008
Did the build_linux.sh script build /usr/local/src/OpenSource_FDO/Utilities/Common?
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
Sent: Tuesday, July 29, 2008 9:47 PM
To: FDO Users Mail List
Subject: Re: [fdo-users] FDO doesn't compile on Debian Linux
is it the bash dash sh problem ?
On Wed, Jul 30, 2008 at 11:46 AM,  <mike at malagatech.com> wrote:
> The second "O" in Source is a typo; the path being used is correct.
> Mike
> On Tue, 29 Jul 2008 15:36:30 -0700, Jack Lee <jack.lee at autodesk.com> wrote:
>> Hi,
>> Is /usr/local/src/OpenSOurce_FDO the correct directory? Notice the second
>> capital O in OpenSOurce_FDO?
>> make[2]: *** No rule to make target
>> '/usr/local/src/OpenSOurce_FDO/Utilities/Common/libProviderCommon.la',
>> needed by 'UnitTest'.  Stop.
>> -----Original Message-----
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of
>> Sent: Tuesday, July 29, 2008 5:42 PM
>> To: fdo-users at lists.osgeo.org
>> Subject: [fdo-users] FDO doesn't compile on Debian Linux
>> I have downloaded version 3.3.1 of FDO to my Debian Linux system.  I'm
>> running the current stable distribution of Debian with the latest
>> updates.
>> I believe I have installed of the required Debian packages to be able to
>> build and install FDO.  In addition to the base FDO source I also
>> downloaded the following providers: ArcSDE, GDAL, GenericRdbms, SHP.  I
>> am
>> able to run "source setenvironment.sh" without an error.  I am able to
>> run
>> "./build_thirdparty.sh" without an error.  When I try to run
>> "./build_linux.sh" or "./build_linux.sh --c release --a buildinstall --m
>> configure --w all" the process works for a while and then dies with the
>> error:
>> make[2]: Leaving directory
>> '/usr/local/src/OpenSource_FDO/Providers/GDAL/Src/UnitTest'
>> make[1]: *** [install-recursive] Error 1
>> make[1]: Leaving directory
>> '/usr/local/src/OpenSource_FDO/Providers/GDAL/Src'
>> make: *** [install-recursive] Error 1
>> Any help would be appreciated,
>> Thank you,
>> Mike Juneau
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the fdo-users mailing list
