[fdo-users] RE: Property2ColNameChar
Dan Stoica dan.stoica at autodesk.com
Wed Jun 11 12:50:06 EDT 2008
" This happens every time you need to access the value of any column via the FDO feature reader."
No. The internal caching is based on the assumption that the properties are fetched in the same order. So the mapping occurs only once, at the 1st ReadNext().
Dan.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Wednesday, June 11, 2008 12:19 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] RE: Property2ColNameChar
> And how would it help in the most common use case, "Select *" ?
OK suppose you do a "select *".
Then you get a feature reader back and you need to read property values, for example for geometry. You call
   Blah = reader->GetGeometry(L"GEOM");
Internally the provider has to map the L"GEOM" to a column index. This happens every time you need to access the value of any column via the FDO feature reader.
Traian
> bounces at lists.osgeo.org] On Behalf Of Dan Stoica
> Sent: Wednesday, June 11, 2008 12:15 PM
> Yes, but it also true that the providers already enhanced will be
> penalized without a real benefit because they have to implement "Get by
> index" :-)
> Dan.
> Sent: Wednesday, June 11, 2008 11:53 AM
> True, but this only applies to some providers. Other providers, which
> can deterministically map property name to index, are penalized
> unnecessarily.
> Traian
> > Sent: Wednesday, June 11, 2008 11:51 AM
> > > we are missing "stanadard" index access to properties and than
> > application can decide which one to use.
> > Even so, the provider has to keep an internal mapping because the
> index
> > of the property doesn't necessary match the index of the
> corresponding
> > column (e.g. RevisionNumber column).
> > Besides, doing everything under the hood has another advantage: it
> > saves the conversion from wchar to char (usually needed when going
> from
> > logical to physical) by caching the char value as well.
> > Dan.
> > bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> > Sent: Wednesday, June 11, 2008 11:15 AM
> > Subject: [fdo-users] RE: Property2ColNameChar
> > I have looked at the code of Property2ColNameChar and few questions
> pop
> > up.
> > I believe when I was developing King.Oracle I was posting that we
> would
> > need to have index access to properties, simillar as database client
> > APIs have. I am not sure but I would be suprised if other database
> > access software have implemented such mechanisems on data access
> level.
> > To me , It looks like that we are missing "stanadard" index access to
> > properties and than application can decide which one to use.
> > Haris
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Dan Stoica
> > Sent: Wednesday, June 11, 2008 4:23 PM
> > Subject: RE: [fdo-users] PostGIS FDO Provider performance issues
> > My bet is that "something else" is the look up for the property in
> the
> > logical/physical collections of properties.
> > E.g. for 20 properties in the class the provider will do aprox.
> > 2,000,000 wide string comparisons for 200,000 rows.
> > Actually it is 4 million because of IsNull() calls. This is the
> > performance killer.
> > The problem has been solved for rdbms providers by caching the
> > properties in the order they are fetched (at the first fetch). So the
> > property will be found either in the same position (after a IsNull)
> or
> > in the next slot. This is equivalent to fetching a property by index
> > rather by name.
> > The implementation is in GenericRdbms:
> > FdoRdbmsFeatureReader::Property2ColNameChar()
> > Hope this helps,
> > Dan.
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> > Sent: Wednesday, June 11, 2008 3:03 AM
> > Subject: Re: [fdo-users] PostGIS FDO Provider performance issues
> > I would agree it's too much overhead, as this happening with Oracle
> as
> > well ( anyone else seen
> > this happen with another db?) perhaps there is something else in
> play.
> > How many rows are fetched by the client? Fetching one row at a time
> is
> > slower than returning blocks of 100 rows..
> > Using mapguide, it's always the mapguide process (ie FDO) and not the
> > database which is showing the high cpu
> > z
> > On Wed, Jun 11, 2008 at 4:56 PM, Carl Jokl <carl.jokl at keynetix.com>
> > wrote:
> > > It is true that there is extra overhead in performing the
> conversion
> > or going
> > > through FDO but I think it is fair to say that having PostGIS 16 to
> > 20
> > times
> > > slower on the same data is more of a performance hit than would
> have
> > been
> > > expected.
> > > View this message in context:
> > http://www.nabble.com/PostGIS-FDO-Provider-performance-issues-
> > tp17756475
> > p17771210.html
> > > Sent from the FDO Users mailing list archive at Nabble.com.
> > > _______________________________________________
> > > fdo-users mailing list
> > > fdo-users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/fdo-users
> > Zac Spitzer -
> > http://zacster.blogspot.com (My Blog)
> > +61 405 847 168
More information about the fdo-users mailing list
