[fdo-users] MPolygon <-> FDO
Jonio, Dennis (Aviation) DJonio at miami-airport.com
Thu Mar 6 13:16:21 EST 2008
Gavin,
It appears, on the surface at least, that DirectPositionImpl is not
returning the same values that it is being handed. Since in my test
case, that I include below, uses a CircularArc2d object I show that
also. That object hands back what it is passed so I am fairly sure that
that is not the issue.
It looks to me that there are rounding and precision differences. But at
least in this case it looks to me like the MPolygon vertices were all
correctly formed.
DirectPositionImpl? Any additional thoughts?
The Points from the Mpolygon
-		p	{Dimensions:[4]}
Autodesk.AutoCAD.Geometry.Point2d[]
+		[0]	{(61.9192385091388,10.2621902206345)}
+		[1]	{(55.2181323514077,1.46976527536452)}
+		[2]	{(70.4772774942939,4.8576720597566)}
+		[3]	{(61.9192385091388,10.2621902206345)}
Iteration:(0)
-		seg_s	{OSGeo.FDO.Geometry.DirectPositionImpl}
+		base	{OSGeo.FDO.Geometry.DirectPositionImpl}
OSGeo.FDO.Runtime.Disposable {OSGeo.FDO.Geometry.DirectPositionImpl}
		Dimensionality	0	int
		M	NaN	double
		X	61.919238509138836	double
		Y	10.262190220634466	double
		Z	NaN	double
the MPolygon says: 61.9192385091388,10.2621902206345
-		seg_e	{OSGeo.FDO.Geometry.DirectPositionImpl}
		M	NaN	double
		X	55.218132351407746	double
		Y	1.4697652753645229	double
		Z	NaN	double
the MPolygon says: 55.2181323514077,1.46976527536452
Iteration:(1)
		M	NaN	double
		Z	NaN	double
		M	NaN	double
		X	70.4772774942939	double
		Y	4.8576720597565952	double
		Z	NaN	double
the Mpolygon says: 70.4772774942939,4.8576720597566
Iteration:(2)
-		dpi_start	{OSGeo.FDO.Geometry.DirectPositionImpl}
		M	NaN	double
		Z	NaN	double
-		dpi_end	{OSGeo.FDO.Geometry.DirectPositionImpl}
		M	NaN	double
		X	61.919238509138843	double
		Y	10.26219022063446	double
		Z	NaN	double
the Mpolygon says: 61.9192385091388,10.2621902206345
The CircularArc2d object
-		ca2d	{Autodesk.AutoCAD.Geometry.CircularArc2d}
+		base	{Autodesk.AutoCAD.Geometry.CircularArc2d}
Autodesk.AutoCAD.Geometry.Curve2d
+		Center	{(61.9192385091388,0.784116063691346)}
		EndAngle	1.1265391183658797	double
+		EndPoint	{(61.9192385091388,10.2621902206345)}
		IsClockWise	false	bool
		Radius	9.4780741569431157	double
+		ReferenceVector	{(0.902930156848995,0.429787310018163)}
Autodesk.AutoCAD.Geometry.Vector2d
		StartAngle	0.0	double
+		StartPoint	{(70.4772774942939,4.8576720597566)}
the Mpolygon says:START = 70.4772774942939,4.8576720597566
the Mpolygon says:END =  61.9192385091388,10.2621902206345
More information about the fdo-users mailing list
