[fdo-users] Error: An exception occurred in FDO component.CLNT_8_UNABLE_TO_LOAD_LIBRARY
Jason Birch Jason.Birch at nanaimo.ca
Fri Mar 28 12:07:59 EDT 2008
The environment that you are using (MapGuide Enterprise, and the Autodesk Oracle provider) are not generally accessible for the open source FDO community.  I would encourage you to follow up through Autodesk Subscription support.
Jason
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of AmilkarQuintero
Sent: Friday, March 28, 2008 08:34
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Error: An exception occurred in FDO component.CLNT_8_UNABLE_TO_LOAD_LIBRARY
Hi, the following error is generated to the Error.Log file in my installation in Linux RH 4 ES.  Has anyone solved this?
<2008-03-28T10:20:14>            Administrator
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute line 103 file OpTestFeatureSourceConnection.cpp
  - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp    An exception occurred in FDO component.
Thanks in advance
here I send some data about my installation
*	The mapserver is Autodesk Mapguide 2008 Enterprise for Linux
*	Linux lucas.siicar.com 2.6.9-67.0.7.ELsmp #1 SMP Wed Feb 27 04:47:23 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
*	The Oracle Instant Client installation
*	/usr/lib/oracle/10.2.0.3/client64/lib
	[root at lucas lib]# ls
	libclntsh.so.10.1  libnnz10.so  libocci.so.10.1  libociei.so  libocijdbc10.so  ojdbc14.jar
In another server we have the Oracle Database with the Spatial Tables we are trying to access
*	The Oracle Server, Oracle RDBMS 10g Release 2
*	Linux juan.siicar.com 2.6.18-53.1.14.el5 #1 SMP Tue Feb 19 07:18:46 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
*	Oracle Database 10g Enterprise Edition Release 10.2.0.1.0 - 64bi
*	PL/SQL Release 10.2.0.1.0 - Production
*	CORE    10.2.0.1.0      Production
*	TNS for Linux: Version 10.2.0.1.0 - Production
*	NLSRTL Version 10.2.0.1.0 - Production
Amilkar Quintero G.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20080328/187c0801/attachment.html
More information about the fdo-users mailing list
