[fdo-users] Error: An exception occurred in FDOcomponent.CLNT_8_UNABLE_TO_LOAD_LIBRARY
AmilkarQuintero amilkar.quintero at gmail.com
Fri Mar 28 15:30:24 EDT 2008
Thanks A lot for your help, but the Autodesk Support in Linux is
verrrryyyyyyyyyyyyyyyyyyyyyyyyyyyyyy disapointing for not saying an obscene
word or phrase.  I created the case nearly a month ago and they "discovered"
that my platform was not windows four days ago.
If any of you see or listen to something like my error, I'll be pleased
thank
Bye
Amilkar
On Fri, Mar 28, 2008 at 2:23 PM, Andy Morsell <amorsell at spatialgis.com>
wrote:
>  I'm with Jason at this point.  Obtaining support directly from Autodesk
> for the non open-source Oracle provider would probably be your best
> bet.......
> Andy
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *AmilkarQuintero
> *Sent:* Friday, March 28, 2008 12:18 PM
> *To:* FDO Users Mail List
> *Subject:* Re: [fdo-users] Error: An exception occurred in
> Andy
> The entry in the providers.xml file has the provider i am invoking
>   <FeatureProvider>
>     <Name>Autodesk.Oracle.3.2</Name>
>     <DisplayName>Autodesk FDO Provider for Oracle</DisplayName>
>     <Description>Read/write access to feature data in an Oracle-based data
> store
> . Supports spatial indexing, long transactions, and persistent
> locking.</Descrip
> tion>
>     <IsManaged>False</IsManaged>
>     <Version>3.2.2.0</Version>
>     <FeatureDataObjectsVersion>3.2.2.0</FeatureDataObjectsVersion>
>     <LibraryPath>/usr/local/fdo-3.2.2/lib/libFdoRdbms.so</LibraryPath>
>   </FeatureProvider>
> and the .so file is there too
> libFdoRdbms.so
> the LD_LIBRARY_PATH points to every lib path in the server
> /usr/lib/oracle:/usr/lib:/usr/lib:/lib:/opt/Autodesk/mapguideenterprise2008/serv
> er/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideent
> erprise2008/webserverextensions/lib:/opt/Autodesk/mapguideenterprise2008/webserv
> erextensions/apache2/lib
> What could have been wrong with the installation
> Thanks
> Amilkar
> On Fri, Mar 28, 2008 at 11:49 AM, Andy Morsell <amorsell at spatialgis.com>
> wrote:
> >  This error generally means that the particular FDO provider that is
> > being referenced by a layer definition is not installed on the server.  Take
> > a look in your /usr/local/fdo-3.3.0/lib directory at the providers.xmlfile.  In that file, find the provider entry for the provider you are trying
> > to use, look at the LibraryPath and see if the .so file that is referenced
> > exists in that directory.  If not, your initial FDO compilation did not
> > create that provider and you will have to trouble-shoot your FDO configure /
> > make process to see if you are missing any environment variables, library
> > dependencies, etc.
> > This page has information that might be helpful:
> > http://mapguide.osgeo.org/2.0/docs/BuildInstallQuickStartLinux.html.
> > Also, be sure to look in your FDO source folder (OpenSource_FDO) for the
> > OpenSourceBuild__README.txt file which has important information regarding
> > building FDO with specific provider support.
> > Andy Morsell, P.E.
> > Spatial Integrators, Inc.
> > http://www.SpatialGIS.com
> > *Sent:* Friday, March 28, 2008 8:34 AM
> > *To:* fdo-users at lists.osgeo.org
> > *Subject:* [fdo-users] Error: An exception occurred in FDO
> >   Hi, the following error is generated to the Error.Log file in my installation in Linux RH 4 ES.  Has anyone solved this?
> > *<2008-03-28T10:20:14> 			Administrator
> >  Error: An exception occurred in FDO component.
> >  StackTrace:
> >   - MgFeatureServiceHandler.ProcessOperation line 83 file FeatureServiceHandler.cpp
> >   - MgOpTestFeatureSourceConnection.Execute line 103 file OpTestFeatureSourceConnection.cpp
> >   - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp	An exception occurred in FDO component.
> > Thanks in advance
> > here I send some data about my installation
> >    - The mapserver is Autodesk Mapguide 2008 Enterprise for Linux
> >    - Linux lucas.siicar.com 2.6.9-67.0.7.ELsmp #1 SMP Wed Feb 27
> >    04:47:23 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
> >    - The Oracle Instant Client installation
> >    - /usr/lib/oracle/10.2.0.3/client64/lib
> >    [root at lucas lib]# ls
> >    libclntsh.so.10.1  libnnz10.so  libocci.so.10.1  libociei.so
> >    libocijdbc10.so  ojdbc14.jar
> > In another server we have the Oracle Database with the Spatial Tables we
> > are trying to access
> >    - The Oracle Server, Oracle RDBMS 10g Release 2
> >    - Linux juan.siicar.com 2.6.18-53.1.14.el5 #1 SMP Tue Feb 19
> >    07:18:46 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
> >    - Oracle Database 10g Enterprise Edition Release 10.2.0.1.0 - 64bi
> >    - PL/SQL Release 10.2.0.1.0 - Production
> >    - CORE    10.2.0.1.0      Production
> >    - TNS for Linux: Version 10.2.0.1.0 - Production
> >    - NLSRTL Version 10.2.0.1.0 - Production
> > Amilkar Quintero G.
> > fdo-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20080328/edc69080/attachment-0001.html
More information about the fdo-users mailing list
