[fdo-users] Error: An exception occurred in FDOcomponent.CLNT_8_UNABLE_TO_LOAD_LIBRARY
Jack Lee jack.lee at autodesk.com
Sat Mar 29 14:11:10 EDT 2008
Have you try tried the 32-bit Oracle client?
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of AmilkarQuintero [amilkar.quintero at gmail.com]
Sent: Saturday, March 29, 2008 12:15 PM
To: FDO Users Mail List
Subject: Re: [fdo-users] Error: An exception occurred in FDOcomponent.CLNT_8_UNABLE_TO_LOAD_LIBRARY
This is a 64bit installation
On Sat, Mar 29, 2008 at 9:52 AM, AmilkarQuintero <amilkar.quintero at gmail.com<mailto:amilkar.quintero at gmail.com>> wrote:
[root at lucas ~]# ls -l /usr/lib/oracle/10.2.0.3/client64/lib/libclntsh.so.10.1
-rw-r--r--  1 root root 20870419 Dec 20  2006 /usr/lib/oracle/10.2.0.3/client64/lib/libclntsh.so.10.1
On Fri, Mar 28, 2008 at 5:31 PM, Jack Lee <jack.lee at autodesk.com<mailto:jack.lee at autodesk.com>> wrote:
What do you get when you execute:
From: fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org> [fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org>] On Behalf Of AmilkarQuintero [amilkar.quintero at gmail.com<mailto:amilkar.quintero at gmail.com>]
Sent: Friday, March 28, 2008 5:56 PM
I also ln -s /usr/lib/oracle/10.2.0.3/client64/lib/libclntsh.so.10.1 libclntsh.so.10.1 to run again the command
ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so
[root at lucas lib]# ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so
       linux-gate.so.1 =>  (0xffffe000)
       libSchemaMgr_OVOR.so => /usr/local/fdo-3.2.2/lib/libSchemaMgr_OVOR.so (0xf76b2000)
       libSchemaMgr_OV-3.2.2.so<http://3.2.2.so><http://3.2.2.so> => /usr/local/fdo-3.2.2/lib/libSchemaMgr_OV-3.2.2.so<http://3.2.2.so><http://3.2.2.so> (0xf767a000)
       libFDO-3.2.2.so<http://libFDO-3.2.2.so><http://libFDO-3.2.2.so> => /usr/local/fdo-3.2.2/lib/libFDO-3.2.2.so<http://3.2.2.so><http://3.2.2.so> (0xf7328000)
       libpthread.so.0 => /lib/tls/libpthread.so.0 (0xf7316000)
       libclntsh.so.10.1 => not found
       libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0xf7221000)
       libm.so.6 => /lib/tls/libm.so.6 (0xf71fe000)
       libgcc_s.so.1 => /lib/libgcc_s.so.1 (0xf71f4000)
       libc.so.6 => /lib/tls/libc.so.6 (0xf70c8000)
       libxalan-c.so => /usr/local/fdo-3.2.2/lib/libxalan-c.so (0xf6dbf000)
       libxalanMsg.so.17 => /usr/local/fdo-3.2.2/lib/libxalanMsg.so.17 (0xf6db7000)
       libxerces-c.so.25 => /usr/local/fdo-3.2.2/lib/libxerces-c.so.25 (0xf6a22000)
       libdl.so.2 => /lib/libdl.so.2 (0xf6a1e000)
       /lib/ld-linux.so.2 (0x56555000)
On Fri, Mar 28, 2008 at 4:40 PM, AmilkarQuintero <amilkar.quintero at gmail.com<mailto:amilkar.quintero at gmail.com><mailto:amilkar.quintero at gmail.com<mailto:amilkar.quintero at gmail.com>>> wrote:
echo $LD_LIBRARY_PATH
# /usr/lib/oracle:/usr/lib/oracle/10.2.0.3/client64/lib:/usr/lib:/usr/lib:/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideenterprise2008/webserverextensions/lib:/opt/Autodesk/mapguideenterprise2008/webserverextensions/apache2/lib
On Fri, Mar 28, 2008 at 4:37 PM, Jack Lee <jack.lee at autodesk.com<mailto:jack.lee at autodesk.com><mailto:jack.lee at autodesk.com<mailto:jack.lee at autodesk.com>>> wrote:
No, you don't need to recompile FDO.
Is libclntsh.so.10.1 not found when you execute ldd?
What is LD_LIBRARY_PATH set to?
From: fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org><mailto:fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org>> [mailto:fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org><mailto:fdo-users-bounces at lists.osgeo.org<mailto:fdo-users-bounces at lists.osgeo.org>>] On Behalf Of AmilkarQuintero
Sent: Friday, March 28, 2008 5:23 PM
Ok, its under /usr/lib/oracle/10.2.0.3/client64/lib
I included in the LD_LIBRARY_PATH and still the error is there, and the command ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so still gives the same answer
do I have to recompile the fdo?
On Fri, Mar 28, 2008 at 3:56 PM, Jack Lee <jack.lee at autodesk.com<mailto:jack.lee at autodesk.com><mailto:jack.lee at autodesk.com<mailto:jack.lee at autodesk.com>>> wrote:
Hi ,
libclntsh.so.10.1 is not found. Can you verify if the file is under /usr/lib/oracle?
Sent: Friday, March 28, 2008 4:53 PM
The answer to the command is
[root at lucas /]# ldd /usr/local/fdo-3.2.2/lib/libFdoRdbms.so
 libpthread.so.0 => /lib/tls/libpthread.so.0 (0xf72ed000)
 libxalan-c.so => /usr/local/fdo-3.2.2/lib/libxalan-c.so (0xf6dc0000)
[root at lucas /]#
And yes, it is included in the LD_LIBRARY_PATH,
/usr/lib/oracle:/usr/lib:/usr/lib:/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideenterprise2008/server/lib:/opt/Autodesk/mapguideenterprise2008/webserverextensions/lib:/opt/Autodesk/mapguideenterprise2008/webserverextensions/apache2/lib
or am I missing the inner directory /usr/lib/oracle/10.2.0.3/client64/lib
On Fri, Mar 28, 2008 at 3:48 PM, Jack Lee <jack.lee at autodesk.com<mailto:jack.lee at autodesk.com><mailto:jack.lee at autodesk.com<mailto:jack.lee at autodesk.com>>> wrote:
If  you entered
are all of the libraries found?
It looks like oracle is installed under /usr/lib/oracle/10.2.0.3/client64/lib but the path is not included in LD_LIBRARY_PATH.
Sent: Friday, March 28, 2008 3:30 PM
Thanks A lot for your help, but the Autodesk Support in Linux is verrrryyyyyyyyyyyyyyyyyyyyyyyyyyyyyy disapointing for not saying an obscene word or phrase.  I created the case nearly a month ago and they "discovered" that my platform was not windows four days ago.
If any of you see or listen to something like my error, I'll be pleased thank
Bye
Amilkar
On Fri, Mar 28, 2008 at 2:23 PM, Andy Morsell <amorsell at spatialgis.com<mailto:amorsell at spatialgis.com><mailto:amorsell at spatialgis.com<mailto:amorsell at spatialgis.com>>> wrote:
I'm with Jason at this point.  Obtaining support directly from Autodesk for the non open-source Oracle provider would probably be your best bet.......
Andy
Sent: Friday, March 28, 2008 12:18 PM
Andy
The entry in the providers.xml file has the provider i am invoking
 <FeatureProvider>
   <Name>Autodesk.Oracle.3.2</Name>
   <DisplayName>Autodesk FDO Provider for Oracle</DisplayName>
   <Description>Read/write access to feature data in an Oracle-based data store
. Supports spatial indexing, long transactions, and persistent locking.</Descrip
tion>
   <IsManaged>False</IsManaged>
   <Version>3.2.2.0<http://3.2.2.0><http://3.2.2.0></Version>
   <FeatureDataObjectsVersion>3.2.2.0<http://3.2.2.0><http://3.2.2.0></FeatureDataObjectsVersion>
   <LibraryPath>/usr/local/fdo-3.2.2/lib/libFdoRdbms.so</LibraryPath>
 </FeatureProvider>
and the .so file is there too
libFdoRdbms.so
the LD_LIBRARY_PATH points to every lib path in the server
What could have been wrong with the installation
Thanks
Amilkar
On Fri, Mar 28, 2008 at 11:49 AM, Andy Morsell <amorsell at spatialgis.com<mailto:amorsell at spatialgis.com><mailto:amorsell at spatialgis.com<mailto:amorsell at spatialgis.com>>> wrote:
This error generally means that the particular FDO provider that is being referenced by a layer definition is not installed on the server.  Take a look in your /usr/local/fdo-3.3.0/lib directory at the providers.xml file.  In that file, find the provider entry for the provider you are trying to use, look at the LibraryPath and see if the .so file that is referenced exists in that directory.  If not, your initial FDO compilation did not create that provider and you will have to trouble-shoot your FDO configure / make process to see if you are missing any environment variables, library dependencies, etc.
This page has information that might be helpful: http://mapguide.osgeo.org/2.0/docs/BuildInstallQuickStartLinux.html.  Also, be sure to look in your FDO source folder (OpenSource_FDO) for the OpenSourceBuild__README.txt file which has important information regarding building FDO with specific provider support.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Friday, March 28, 2008 8:34 AM
To: fdo-users at lists.osgeo.org<mailto:fdo-users at lists.osgeo.org><mailto:fdo-users at lists.osgeo.org<mailto:fdo-users at lists.osgeo.org>>
Subject: [fdo-users] Error: An exception occurred in FDO component.CLNT_8_UNABLE_TO_LOAD_LIBRARY
Hi, the following error is generated to the Error.Log file in my installation in Linux RH 4 ES.  Has anyone solved this?
<2008-03-28T10:20:14>            Administrator
 StackTrace:
 - MgFeatureServiceHandler.ProcessOperation line 83 file FeatureServiceHandler.cpp
 - MgOpTestFeatureSourceConnection.Execute line 103 file OpTestFeatureSourceConnection.cpp
 - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp    An exception occurred in FDO component.
Thanks in advance
here I send some data about my installation
 *   The mapserver is Autodesk Mapguide 2008 Enterprise for Linux
 *   Linux lucas.siicar.com<http://lucas.siicar.com><http://lucas.siicar.com> 2.6.9-67.0.7.ELsmp #1 SMP Wed Feb 27 04:47:23 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
 *   The Oracle Instant Client installation
 *   /usr/lib/oracle/10.2.0.3/client64/lib
[root at lucas lib]# ls
libclntsh.so.10.1  libnnz10.so  libocci.so.10.1  libociei.so  libocijdbc10.so  ojdbc14.jar
In another server we have the Oracle Database with the Spatial Tables we are trying to access
 *   The Oracle Server, Oracle RDBMS 10g Release 2
 *   Linux juan.siicar.com<http://juan.siicar.com><http://juan.siicar.com> 2.6.18-53.1.14.el5 #1 SMP Tue Feb 19 07:18:46 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
 *   Oracle Database 10g Enterprise Edition Release 10.2.0.1.0 - 64bi
 *   PL/SQL Release 10.2.0.1.0 - Production
 *   CORE    10.2.0.1.0      Production
 *   TNS for Linux: Version 10.2.0.1.0 - Production
 *   NLSRTL Version 10.2.0.1.0 - Production
Amilkar Quintero G.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
