[fdo-users] Define a SQL as source instead of a tablename (MySQL)
Alexander Bruch abruch at e-vend.de
Thu May 8 10:58:06 EDT 2008
Hello,
is it possible or will it be possible in near future to provide a SQL as
datasource instead of using static tables?
i.e. if i use mapguide studio to define a Layer, and i select a datasource,
than i can only choose Tables or views, which are defined in MySQL.
What i want is to enter a SQL, which should be used as Feature Source.
It is not enough for me to define Queryfilters basedd on tables, because the
datasource (SQL) is build up on complex joins which includes userids.
Is this possible in FDO?
Or is this just a missing feature in the Mapguide Server?
thank you for answer
Alexander Bruch
View this message in context: http://www.nabble.com/Define-a-SQL-as-source-instead-of-a-tablename-%28MySQL%29-tp17127289p17127289.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
