[fdo-users] King FDO Point Layer error
btenbroeck btenbroeck at gmail.com
Fri May 16 11:01:32 EDT 2008
I just get an "unhandled exception" in fdo2fdo. Opening in Visual Studio
doesn't shed any light, as it says there is no debug info. BTW, this is a
Materialized View, and the layer is defined as KingFdoPoint. When defined as
a traditional view, the same thing happens.
(I tried swapping the dlls in FDO2FDO and you are correct, it tosses an
error when opening the app)
haris kurtagic wrote:
> Hm, I am not sure but I think not.
> I belive we haven't released Fdo2Fdo with FDO 3.3 ( Simon will do it
> soon ).
> Perhaps if you try with Fdo2Fdo as it is to see if that  works. That
> could help us determine if it is something with latest 3.3 version or
> not.
> Haris
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of btenbroeck
> Sent: Friday, May 16, 2008 3:57 PM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] King FDO Point Layer error
> 10Gr2 and FDO 3.3. Can I replace the dlls in FDO2FDO 0.74 and have it
> work?
>> What are your version of Oracle and provider ?
>> Can you try with Fdo2Fdo to read that table ?
>> Haris
>> Sent: Thursday, May 15, 2008 10:13 PM
>> Subject: [fdo-users] King FDO Point Layer error
>> I have a point layer that works using the Autodesk provider, but when
> I
>> use
>> the same table via King, it throws an "unspecified" error, and kills
> the
>> MGE
>> process. Is there any way I can trap more info to pass along?
>> View this message in context:
> http://www.nabble.com/King-FDO-Point-Layer-error-tp17190016p17190016.htm
>> l
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> http://www.nabble.com/King-FDO-Point-Layer-error-tp17190016p17275367.htm
> l
View this message in context: http://www.nabble.com/King-FDO-Point-Layer-error-tp17190016p17276863.html
More information about the fdo-users mailing list
