[fdo-users] King FDO Point Layer error
Haris Kurtagic haris at sl-king.com
Fri May 16 11:57:20 EDT 2008
Great, I will contact you on your private email.
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bill Ten Broeck
Sent: Friday, May 16, 2008 5:50 PM
To: FDO Users Mail List
Subject: Re: [fdo-users] King FDO Point Layer error
I'd be glad to give it a shot.
Haris Kurtagic wrote:
> I see you use Visual Studio, I culd send you debug version of provider
> and source code If you are willing to look into it.
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of btenbroeck
> Sent: Friday, May 16, 2008 5:02 PM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] King FDO Point Layer error
> I just get an "unhandled exception" in fdo2fdo. Opening in Visual
Studio
> doesn't shed any light, as it says there is no debug info. BTW, this
is
> a
> Materialized View, and the layer is defined as KingFdoPoint. When
> defined as
> a traditional view, the same thing happens.
> (I tried swapping the dlls in FDO2FDO and you are correct, it tosses
an
> error when opening the app)
> haris kurtagic wrote:
>> Hm, I am not sure but I think not.
>> I belive we haven't released Fdo2Fdo with FDO 3.3 ( Simon will do it
>> soon ).
>> Perhaps if you try with Fdo2Fdo as it is to see if that  works. That
>> could help us determine if it is something with latest 3.3 version or
>> not.
>> Haris
>> Sent: Friday, May 16, 2008 3:57 PM
>> 10Gr2 and FDO 3.3. Can I replace the dlls in FDO2FDO 0.74 and have it
>> work?
>>> What are your version of Oracle and provider ?
>>> Can you try with Fdo2Fdo to read that table ?
>>> Haris
>>> Sent: Thursday, May 15, 2008 10:13 PM
>>> Subject: [fdo-users] King FDO Point Layer error
>>> I have a point layer that works using the Autodesk provider, but
when
>> I
>>> use
>>> the same table via King, it throws an "unspecified" error, and kills
>> the
>>> MGE
>>> process. Is there any way I can trap more info to pass along?
>>> View this message in context:
http://www.nabble.com/King-FDO-Point-Layer-error-tp17190016p17190016.htm
>>> l
>>> Sent from the FDO Users mailing list archive at Nabble.com.
>>> fdo-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
http://www.nabble.com/King-FDO-Point-Layer-error-tp17190016p17275367.htm
>> l
More information about the fdo-users mailing list
