[fdo-users] bulkcopy ArcSDE -> SQLite
alucas alucas at srtec.com
Mon Nov 10 12:55:08 EST 2008
Do you know if I can use the bulkcopy API in a standalone application? If
yes, there is any documentation about how to use this API?
Thanks.
Traian Stanev wrote:
> I don't think anybody has tried to use BulkCopy to output SQLite yet. In
> theory it should work... If it does not, you can always bulk copy to SDF
> and then use the SQLiteConverter which comes with the provider to convert
> the SDF to SQLite, and also create a Trac ticket against the SQLite
> provider, describing the problem.
> Traian
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>> bounces at lists.osgeo.org] On Behalf Of alucas
>> Sent: Monday, November 10, 2008 12:47 PM
>> To: fdo-users at lists.osgeo.org
>> Subject: RE: [fdo-users] bulkcopy ArcSDE -> SQLite
>> Hello Traian,
>> The used by the FDO provider.
>> Thanks
>> > Which SQLite format are you talking about? The one used by the SQLite
>> FDO
>> > provider, or some generic SQL format?
>> > Traian
>> >> Sent: Monday, November 10, 2008 4:24 AM
>> >> Subject: [fdo-users] bulkcopy ArcSDE -> SQLite
>> >> Hello,
>> >> It's possible to do this bulkcopy?
>> >> Thanks in advance.
>> >> View this message in context: http://www.nabble.com/bulkcopy-ArcSDE-
>> >> %3E-SQLite-tp20416688p20416688.html
>> >> Sent from the FDO Users mailing list archive at Nabble.com.
>> >> _______________________________________________
>> >> fdo-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> View this message in context: http://www.nabble.com/bulkcopy-ArcSDE--
>> %3E-SQLite-tp20416688p20424669.html
View this message in context: http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20424807.html
More information about the fdo-users mailing list
