[fdo-users] bulkcopy ArcSDE -> SQLite
alucas alucas at srtec.com
Thu Nov 13 03:38:49 EST 2008
Hi Robert,
I understand this, but I only need to do the bulkcopy from ArcSDE -> SQLite.
So, I think that schema creation is only required for SQLite provider. So,
if SQLite provider allows schema creation, in theory I can bulkcopy the data
from any source.
Is this correct?
Thanks.
P.D: Sorry for my english.
Robert Fortin wrote:
> Jackie is right all the way.
> ArcSDE provider doesn't let you create or modify new schema so you must
> have an existing schema for ArcSDE and do the mapping between the source
> and the target schema. The most common problem encountered is a wrong
> mapping to the existing schema which triggers Bulkcopy to try to alter the
> schema. This fails because the provider doesn't support schema
> creation/modification.
> RF
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
> Sent: Wednesday, November 12, 2008 3:50 PM
> To: fdo-users at lists.osgeo.org
> Subject: Re: [fdo-users] bulkcopy ArcSDE -> SQLite
> That's a question that should be asked to Autodesk (or their official
> discussion channels) instead, as the BulkCopy component is part of the Map
> ObjectARX SDK and not the open source FDO.
> But I would guess in theory any provider is a valid bulk copy source and
> any
> provider that supports write and schema creation/modification is a valid
> bulk copy target.
> - Jackie
> alucas wrote:
>> Hi Jackie,
>> I don't try this option. I'll see this in the next days. My question is
>> about if the provider will support bulkcopy operations with AutoCAD Map
>> 3D.
>> Thanks.
>> Jackie C. Ng wrote:
>>> Have you tried using FDO Toolbox to do this?
>>> - Jackie
>>> alucas wrote:
>>>> Hello,
>>>> It's possible to do this bulkcopy?
>>>> Thanks in advance.
>>>> View this message in context:
>>>> http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20416688.html
>>>> Sent from the FDO Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> fdo-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>>> http://n2.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp1479828p1482578.html
>>> http://themapguyde.blogspot.com
>>> http://www.linkedin.com/in/jackieng
> http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20469080.html
View this message in context: http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20476696.html
More information about the fdo-users mailing list
