[fdo-users] ArcSDE questions
George McLean gmclean at gorge.net
Thu Nov 13 10:23:12 EST 2008
Thanks Matt - I can connect, I just do not see the feature class listed
that I created using ArcCatalog.
Matt Winger wrote:
> Did you copy the dll files from SDE into the Map > FDO > Bin directory.
> There's a white paper from Autodesk on how to connect to an SDE server.
> I think they are sde.dll, pe.dll, and sg.dll.
> If you don't have those in place it will not connect.
> Matt Winger
> GIS Application Engineer
> mwinger at rand.com
> T: 866-485-5220 x203|C: 517-781-0216
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of George McLean
> Sent: Tuesday, November 11, 2008 6:13 PM
> To: FDO Users Mail List
> Subject: [fdo-users] ArcSDE questions
> I have a few of questions related to ArcSDE.
> I am using ArcSDE 9.3 with SQLServer 2005 as the database and the dbo
> user. I am starting with an empty schema. Through ArcCatalog I have
> created a line feature class. However, I can not see the feature class
> listed when I connect through Autocad Map's display manager. When I
> connect there are no features listed to bring onto the map. Not having
> much experience with ArcCatalog, I would like to know if creating a
> feature class is what I need to do to see features in Autocad. If so,
> are there any special considerations in building the feature class?
> Also, at this point there is no data in the feature class. Could this be
> why it is not listed in the display manger connection?
> Finally, I have some .net code that I use to port data from Autocad into
> an FDO datastore. It works with Oracle and MySQL. I am not sure of the
> connection strong parameters required to connect to ArcSDE. In my code I
> create a string as follows:
> "service=MyService; username=MyUser; password=MyPass;
> datastore=MyDataStore"
> What I am not sure about is what to put in for MyService and MyDataStore
> when using ArcSDE.
> I have tried the GIS server name for MyService and the schema name for
> MyDataStore but I can not connect.
> Any guidance on any of these questions would be greatly appreciated!
> Thanks
> George McLean
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.175 / Virus Database: 270.9.2/1783 - Release Date: 11/12/2008 10:01 AM
More information about the fdo-users mailing list
