[fdo-users] PostGIS Provider
Ary.Sucaya ary.sucaya at yahoo.com
Tue Nov 18 03:38:40 EST 2008
Hii all,
Can anybody confirm that postgis fdo 3.3 work well with map3d 2009? I'm
working with map3d geospatial API and I found map3d crash when i tried to
insert a postgis feature. i also found that postgis layer couldn't added to
layer group programatically. My code have no error with SHP and SDF provider
but postgis provider. I was wondering if i am the only one who experience
the error?
kind regards,
ary sucaya
Robert Fortin wrote:
> Thanks Mike!  That's very valuable info.
> I will contact Bruno.
> Robert
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Michael Toews
> Sent: Thursday, October 23, 2008 11:14 AM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] PostGIS Provider
> Yes!
> See notes at http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
> At my workplace, we've been using the provider with AutoCAD Map 3D 2008
> with FDO 3.2 (working toward a production environment really soon), and
> I've also tested PostGIS with MGOS 2.0.2/FDO 3.3. The Win32 DLLs are
> from Bruno:
> http://www.geomapgis.com/web/geomap-group/fdo/
> and modify the providers.xml file as explained on the Wiki.
> However, the provider is beta quality, having many limitations
> (explained in wiki), for example:
>    1. Use all lowercase for database name, schema (datastore), table and
>       column names
>    2. Use simple data types for all tables in a schema (no timestampz,
>       text[] or custom types allowed). Character, integer, real, float,
>       date, and timestamp data types appear to be OK.
>    3. Views can be used, but cannot be edited (even if rules are written
>       for it). They just need to appear in the public.spatial_columns
>       table, and I think the intended primary key needs to be in the
>       first column.
> If you have a complicated database with "advanced" data types used in
> your tables, you might want add another schema "fdo" for FDO
> applications. This way, you can keep all the data types used in the
> "fdo" schema tables to basic types, while the other tables in the
> non-fdo schemas can use "advanced" data types.
> Also, if you have "advanced" data types as columns in spatial tables,
> you need to export this as a view in a different schema casting these
> columns as text (or not showing them). If these spatial tables need to
> be editable by FDO clients (i.e., CAD), then you need to emulate a view
> using two tables in two schemas with trigger functions to synchronize
> changes between the two tables (I have a template for this).
> Good luck!
> -Mike
>> Hi,
>> Has anybody been using the PostGIS FDO provider with Map or MapGuide?
>> I’d be interested in knowing how it worked for you.
>> Robert
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/PostGIS-Provider-tp20132072p20555442.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
