[fdo-users] SDE Error - Cant fine feature class
Dan Stoica dan.stoica at autodesk.com
Wed Oct 1 10:49:40 EDT 2008
You need to do:
                connection->SetConnectionString(<your SDF file path>);
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of surrounded
Sent: Wednesday, October 01, 2008 10:22 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] SDE Error - Cant fine feature class
I establish a connection to SDE enterprise geodatabase:
I use the following code to access the feature class:
    connection = getSDEConnection("OSGeo.ArcSDE.3.3");
    OSGeo.FDO.Commands.Feature.ISelect sel =
    reader = sel.Execute();
On the sel.Execute I get the following error:
    Feature class 'Cities' not found in schema.
Any ideas on why this is happening....Thanks
View this message in context: http://n2.nabble.com/SDE-Error---Cant-fine-feature-class-tp1131496p1131496.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
More information about the fdo-users mailing list
