[fdo-users] SDE Error - Cant fine feature class
Dan Stoica dan.stoica at autodesk.com
Wed Oct 1 11:54:34 EDT 2008
Sorry, I cannot help with this one...
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of surrounded
Sent: Wednesday, October 01, 2008 10:59 AM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] SDE Error - Cant fine feature class
Hi Dan, Thanks
I get the following error when I try this:
    'The connection is already open'
string providerName = getProviderName("arcsdeprovider.dll");
                //OPEN CONNECTION
connection = getSDEConnection(providerName);
connection.ConnectionString = SDEName;   //WHERE SDEName = "Cities".  THIS
IS LINE OF ERROR
OSGeo.FDO.Commands.Feature.ISelect sel =
(OSGeo.FDO.Commands.Feature.ISelect)
connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select);
getSDEConnection returns a IConnection:  code below
IConnectionManager connectionManager =
FeatureAccessManager.GetConnectionManager();
IConnection connection = connectionManager.CreateConnection(providerName);
IConnectionPropertyDictionary connectionPropertyDictionary;
connectionPropertyDictionary =
connection.ConnectionInfo.ConnectionProperties;
connectionPropertyDictionary.SetProperty("Server", "server");
connectionPropertyDictionary.SetProperty("Instance", "5151");
connectionPropertyDictionary.SetProperty("Username", "username");
connectionPropertyDictionary.SetProperty("Password", "password");
connectionPropertyDictionary.SetProperty("Datastore", "database");
OSGeo.FDO.Connections.ConnectionState connectState = connection.Open();
surrounded wrote:
> I establish a connection to SDE enterprise geodatabase:
> I use the following code to access the feature class:
>     connection = getSDEConnection("OSGeo.ArcSDE.3.3");
>     sel.SetFeatureClassName("Cities");
>     reader = sel.Execute();
> On the sel.Execute I get the following error:
>     Feature class 'Cities' not found in schema.
> Any ideas on why this is happening....Thanks
View this message in context: http://n2.nabble.com/SDE-Error---Cant-fine-feature-class-tp1131496p1131615.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
