[fdo-users] Spatial Filter Help Needed
surrounded Rob.Sosnowski at itd.idaho.gov
Thu Oct 2 12:56:53 EDT 2008
Hi Jackie,
Can you give an idea of how to apply the filter to the select command.  I
thought the sel.SetFilter did that.  Perhaps, I'll try  sel.Filter =
Filter.Parse(pPtLineFilter.toString());
I will also try Geometry.
Thanks.....
Jackie Ng wrote:
> I see two things:
> 1) The filter is being created but not being applied to the select
> command.
> 2) I don't think you can apply filters on "aliased" properties. You should
> be able to filter on the "Geometry" property and get the same result.
> - Jackie
> surrounded wrote:
>> I'm trying to intersect a circle (created from input coordinates) with a
>> shapefile.  I've created the circle geometry and am now trying to set up
>> the filter.  In the code below, the statement
>> while(reader.ReadNext())
>> throws the follwing exception:
>> "The property 'Shape' is not in the readers selected property set"
>> SUGGESTIONS....THANKS
>> OSGeo.FDO.Expression.GeometryValue pGVal = new
>> GeometryValue(pByteCircle);
>> OSGeo.FDO.Expression.ComputedIdentifier pPropName = new
>> ComputedIdentifier("Shape", new Identifier("Geometry"));
>> IdentifierCollection pIDColl = sel.PropertyNames;
>> pIDColl.Add(pPropName);
>> OSGeo.FDO.Filter.Filter pPtLineFilter = new
>> OSGeo.FDO.Filter.SpatialCondition(pPropName,
>> OSGeo.FDO.Filter.SpatialOperations.SpatialOperations_Intersect, pGVal); }
>> OSGeo.FDO.Commands.Feature.IFeatureReader reader = sel.Execute();
>> while (reader.ReadNext())
>>      ......some code....
View this message in context: http://n2.nabble.com/Spatial-Filter-Help-Needed-tp1134329p1134371.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
