[fdo-users] GML FDO OGR
Traian Stanev traian.stanev at autodesk.com
Wed Oct 15 10:47:15 EDT 2008
Hi Luc,
I don't think anybody has tried reading GML with the OGR provider, so you'd be the first.
The provider DLL you have is likely dynamically linked to the GDAL dll. If the GDAL dll you are using has been compiled with GML support (in theory) the provider could read GML. The way to figure that out is to check whether the GDAL dll depends on Xerces.
Traian
P.S. I have done some builds of the provider, where it links to GDAL statically and it is not possible to simply replace the GDAL dll to add GML support. You know if you have one of these if the provider dll is bigger than a meg.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of lucvanlinden
> Sent: Wednesday, October 15, 2008 3:09 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] GML FDO OGR
> thanks Dennis, but this is a complete other issue and has nothing to do
> with
> oracle.
> Has anyone used the FDO OGR provider with GML? any advice is welcome.
> tx
> Luc
> djonio wrote:
> > Luc,
> > Thanks for your input on the OTN forum!
> > "SDO_UTIL.REMOVE_DUPLICATE_VERTICES with curves"
> > With your obvious knowledge of the sdo_geometry object I wish to
> > respectfully ask: Why are you going down this road? Am I missing a
> piece
> > of the puzzle?
> > r,
> > dennis
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of lucvanlinden
> > Sent: Tuesday, October 14, 2008 7:34 AM
> > Subject: [fdo-users] GML FDO OGR
> > I understand that the OGR FDO provider is capable of reading GML
> files
> > only
> > when compiled with xerces support.
> > How do I know if this is the case? In Map 3D for example, same for
> Kings
> > fdo2fdo I see that the xerces.dll files are listed in the fdo
> folders.
> > However when trying to connect to a simple GML file (2.1.2 version)
> it
> > fails
> > to connect.
> > So in general how should it be possible to use the OGR provider with
> GML
> > file and specifically, has anyone succeeded in this?
> > tx
> > Luc
> > View this message in context:
> > http://www.nabble.com/GML-FDO-OGR-tp19971700p19971700.html
> > Sent from the FDO Users mailing list archive at Nabble.com.
> > fdo-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/fdo-users
> > E-mails are automatically scanned for viruses using McAfee.
> View this message in context: http://www.nabble.com/GML-FDO-OGR-
> tp19971700p19987979.html
More information about the fdo-users mailing list
