[fdo-users] ArcSDE 9.2
Thomas Knoell thomas.knoell at autodesk.com
Mon Oct 20 18:39:48 EDT 2008
Hi George,
The *_lineage tables are relevant when loading version-related data. To retrieve the version names in the dialog you should have access to the VERSION and STATES tables. Do you see those tables?
Also, do you know how that data store was created?
Thanks
  Thomas
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of gmclean at gorge.net
Sent: Monday, October 20, 2008 6:17 PM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] ArcSDE 9.2
The only table I have from the list is
dbo.SDE_state_lineages. There is one record:
lineage_name = 0
lineage_id = 0
Thanks,
George
------- Original Message -------
>From    : Jack Lee[mailto:jack.lee at autodesk.com]
Sent    : 10/20/2008 2:29:50 PM
To      : fdo-users at lists.osgeo.org
Cc      :
Subject : RE: [fdo-users] ArcSDE 9.2
Does your datastore contains any of the following tables?
sde.state_lineages
sde.sde_state_lineages
sde.sde.state_lineages
sde.sde.sde_state_lineages
Of Romica Dascalescu
Sent: Monday, October 20, 2008 4:41 PM
To: FDO Users Mail List
Hi George,
There is a patch for Map2008 and ArcSDE provider
using 92 server.
The fix is not under Windows SDK its under "Patches"
- Ticket #294
http://fdo.osgeo.org/content/fdo-323-downloads
http://download.osgeo.org/fdo/3.2.3/patches/ticket294/fdoarcsde-3.2.3_win32_release_G071.tar.gz
Romy.
Of George McLean
Sent: Monday, October 20, 2008 3:49 PM
Subject: [fdo-users] ArcSDE 9.2
I am working through my first attempt to use the
ArcSDE provider.
I am connecting through Autocad Map 2008 to an ArcSDE
system running SQL
Server. In the data provider, I am able to log in and
see one data
store. I get an error message when I attempt to get
the version list.
The error states
-37 DMBS table not found
then
State info list could not be retrieved
I am not sure how to determine what table is missing.
Any suggestions?
This data store was set up by the GIS Administrator
for my client and
currently has no GIS data loaded. I am hoping I can
move data and table
defmitions from a MySQL data store to the ArcSDE
datastore through
Autocad's Bulc Copy. Will this work?
Thanks
George McLean
fdo-users mailing list
 http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
