[fdo-users] Arc SDE 9.3
George McLean gmclean at gorge.net
Wed Oct 22 18:05:06 EDT 2008
Hi Robert,
I am not sure how to try the 3.4 build but this is what I have done so far:
I downloaded the fdosdk_3.4.0_win32_release_G032.tar and copied the
dills and providers.xml file into the FDO\bin folder in my map 2009
installation. When I do this and start Map 2009,  mapstartwspace fails
so I do not get the task pane. Should this approach work? I am guessing
that I do not understand all the steps required to make this work.
I tried connecting to ArcSDE using the version 3.3.2 providers but that
failed with the error: DBMS table not found (-37).The GIS Administrator
has been able to create a feature class using ArcCatalog with the same
account I am using to access the data store so I don't think this is a
permissions issue.
Any suggestions? Thanks again for the help.
George
Robert Fortin wrote:
> George,
> As long as you don't use a dbo user, it should work.  See my response to Jason too.
> Just remembr that this is unofficial build of 3.4 so it's WORK-IN-PROGRESS still.
> See the road map page for the release plan for FDO 3.4 http://fdo.osgeo.org/content/road-map
> Robert
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of gmclean at gorge.net
> Sent: Tuesday, October 21, 2008 2:35 PM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] Arc SDE 9.3
> Thanks Robert, this does help. I was not trying to
> stir things up too much with the thread I posted. I
> just needed to know how relevant it was compared to
> the present state of FDO and ArcSDE so I could take
> that information back to the GIS administrator I am
> working with.
> If I understand you correctly, the weekly build will
> support SQL Server with SQL Server Authentication. Is
> that correct?
> Thanks again.
> George
> ------- Original Message -------
> >From    : Robert
> Fortin[mailto:robert.fortin at autodesk.com]
> Sent    : 10/21/2008 9:30:00 AM
> To      : fdo-users at lists.osgeo.org
> Cc      :
> Subject : RE: [fdo-users] Arc SDE 9.3
>  George,
> The thread you mention is not only 1.5 years old but
> also talks about Map 2007 which has been released in
> April 2006.  It is using much  older version of the
> ArcSDE FDO provider. Since then Map 2008 and Map 2009
> have been released on updated FDO version and support
> for 9.2 has been added to ArcSDE Provider.  Some of
> the problem discussed there are of course outdated
> mainly the multiple connection issue inside Map.
> We already posted an unofficial version of the ArcSDE
> provider supporting 9.3. At the moment, it won't
> support dbo user (on SQL Server) or Windows
> authentication but it is the plan to support those
> features in the 3.4 release.  Unofficial build can be
> downloaded from here
> http://download.osgeo.org/fdo/3.4.0/weekly/.
> Some user on this thread have actually indicated that
> they used the existing provider using 9.3 client
> components against 9.3 server without any problem.
> As Romy mentioned, you can download the latest patch
> for the provider depending on the version of FDO you
> want to use.  Go to the FDO download page
> http://fdo.osgeo.org/content/downloads.
> Hope it helps.
> Robert
> Sent: Tuesday, October 21, 2008 11:56 AM
> Subject: [fdo-users] Arc SDE 9.3
> Is there any estimate on when FDO will support ArcSDE
> 9.3?
> The GIS administrator I am working with pointed me to
> the thread below from an ESRI forum that says some
> interesting things about FDO and SDE. I would be
> interested in other FDO users experience with SDE
> regarding stability, locking tables, database
> connections etc. I realize the thread is over a year
> old and there may have been some changes since these
> comments were posted.
>  http://forums.esri.com/Thread.asp?c=2&f=59&t=216609&mc=9
> Thanks
> George McLean
> fdo-users mailing list
>  http://lists.osgeo.org/mailman/listinfo/fdo-users
> No virus found in this incoming message.
> Checked by AVG - http://www.avg.com
> Version: 8.0.175 / Virus Database: 270.8.2/1737 - Release Date: 10/21/2008 9:10 AM
More information about the fdo-users mailing list
