[fdo-users] Arc SDE 9.3
George McLean gmclean at gorge.net
Thu Oct 23 20:27:27 EDT 2008
Thanks Robert.
As I understand it, to use the sde user, the tables would need to be
moved to the sde schema. Is that correct? If so, I am not sure if I
could get the GIS administrator to go for that.
If I can not get the schema changed, is there a rough idea of when the
provider would support the dbo user.
Thanks again.
George
Robert Fortin wrote:
> George,
> Using dbo instead of sde user is new to 9.3 and we are looking into fixing this issue in the provider.
> Unless you switch to using a sde user, it will not work at the moment.
> Robert
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of George McLean
> Sent: Thursday, October 23, 2008 11:56 AM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] Arc SDE 9.3
> It looks like it is dbo.SDE_state_lineages. Does this mean the current
> provider will not work?
> Thanks
> George
> Jack Lee wrote:
>> Hi,
>> In SQL Server Management Studio, do you have a table named sde.SDE_state_lineages or dbo.SDE_state_lineages?
>> Sent: Wednesday, October 22, 2008 8:36 PM
>> I am getting the error when retrieving the versions.
>> I am not sure if I am using the sde user. How can I verify that? When I
>> connect directly to the database through SQL Server Management Studio, I
>> see the user defined in the security tab. Does the user need to be
>> defined for sde separately?
>> Thanks
>> George
>> Jack Lee wrote:
>>> Hi,
>>> Fdo 3.4 dlls are not binary compatible with Map 2009 which uses Fdo 3.3.2.
>>> Are you using the dbo user or sde user?
>>> Did you get the error message when retrieving the versions?
>>> ________________________________________
>>> From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of George McLean [gmclean at gorge.net]
>>> Sent: Wednesday, October 22, 2008 6:05 PM
>>> Hi Robert,
>>> I am not sure how to try the 3.4 build but this is what I have done so far:
>>> I downloaded the fdosdk_3.4.0_win32_release_G032.tar and copied the
>>> dills and providers.xml file into the FDO\bin folder in my map 2009
>>> installation. When I do this and start Map 2009,  mapstartwspace fails
>>> so I do not get the task pane. Should this approach work? I am guessing
>>> that I do not understand all the steps required to make this work.
>>> I tried connecting to ArcSDE using the version 3.3.2 providers but that
>>> failed with the error: DBMS table not found (-37).The GIS Administrator
>>> has been able to create a feature class using ArcCatalog with the same
>>> account I am using to access the data store so I don't think this is a
>>> permissions issue.
>>> Any suggestions? Thanks again for the help.
>>> George
>>>> George,
>>>> As long as you don't use a dbo user, it should work.  See my response to Jason too.
>>>> Just remembr that this is unofficial build of 3.4 so it's WORK-IN-PROGRESS still.
>>>> See the road map page for the release plan for FDO 3.4 http://fdo.osgeo.org/content/road-map
>>>> Robert
>>>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of gmclean at gorge.net
>>>> Sent: Tuesday, October 21, 2008 2:35 PM
>>>> To: fdo-users at lists.osgeo.org
>>>> Subject: RE: [fdo-users] Arc SDE 9.3
>>>> Thanks Robert, this does help. I was not trying to
>>>> stir things up too much with the thread I posted. I
>>>> just needed to know how relevant it was compared to
>>>> the present state of FDO and ArcSDE so I could take
>>>> that information back to the GIS administrator I am
>>>> working with.
>>>> If I understand you correctly, the weekly build will
>>>> support SQL Server with SQL Server Authentication. Is
>>>> that correct?
>>>> Thanks again.
>>>> George
>>>> ------- Original Message -------
>>>> >From    : Robert
>>>> Fortin[mailto:robert.fortin at autodesk.com]
>>>> Sent    : 10/21/2008 9:30:00 AM
>>>> To      : fdo-users at lists.osgeo.org
>>>> Cc      :
>>>> Subject : RE: [fdo-users] Arc SDE 9.3
>>>>  George,
>>>> The thread you mention is not only 1.5 years old but
>>>> also talks about Map 2007 which has been released in
>>>> April 2006.  It is using much  older version of the
>>>> ArcSDE FDO provider. Since then Map 2008 and Map 2009
>>>> have been released on updated FDO version and support
>>>> for 9.2 has been added to ArcSDE Provider.  Some of
>>>> the problem discussed there are of course outdated
>>>> mainly the multiple connection issue inside Map.
>>>> We already posted an unofficial version of the ArcSDE
>>>> provider supporting 9.3. At the moment, it won't
>>>> support dbo user (on SQL Server) or Windows
>>>> authentication but it is the plan to support those
>>>> features in the 3.4 release.  Unofficial build can be
>>>> downloaded from here
>>>> http://download.osgeo.org/fdo/3.4.0/weekly/.
>>>> Some user on this thread have actually indicated that
>>>> they used the existing provider using 9.3 client
>>>> components against 9.3 server without any problem.
>>>> As Romy mentioned, you can download the latest patch
>>>> for the provider depending on the version of FDO you
>>>> want to use.  Go to the FDO download page
>>>> http://fdo.osgeo.org/content/downloads.
>>>> Hope it helps.
>>>> Robert
>>>> Sent: Tuesday, October 21, 2008 11:56 AM
>>>> Subject: [fdo-users] Arc SDE 9.3
>>>> Is there any estimate on when FDO will support ArcSDE
>>>> 9.3?
>>>> The GIS administrator I am working with pointed me to
>>>> the thread below from an ESRI forum that says some
>>>> interesting things about FDO and SDE. I would be
>>>> interested in other FDO users experience with SDE
>>>> regarding stability, locking tables, database
>>>> connections etc. I realize the thread is over a year
>>>> old and there may have been some changes since these
>>>> comments were posted.
>>>>  http://forums.esri.com/Thread.asp?c=2&f=59&t=216609&mc=9
>>>> Thanks
>>>> George McLean
>>>> _______________________________________________
>>>> fdo-users mailing list
>>>>  http://lists.osgeo.org/mailman/listinfo/fdo-users
>>>> No virus found in this incoming message.
>>>> Checked by AVG - http://www.avg.com
>>>> Version: 8.0.175 / Virus Database: 270.8.2/1737 - Release Date: 10/21/2008 9:10 AM
>>> Version: 8.0.175 / Virus Database: 270.8.2/1738 - Release Date: 10/21/2008 2:10 PM
> Version: 8.0.175 / Virus Database: 270.8.2/1741 - Release Date: 10/23/2008 7:54 AM
More information about the fdo-users mailing list
