[fdo-users] FDO provider for G/Technology
Zac Spitzer zac.spitzer at gmail.com
Wed Sep 17 00:54:31 EDT 2008
depending on your performance requirements, db FDO mightn't cut it performance
wise. SDF /SHP generally perform a lot better. you might want to
consider writing out
you data into an SDF file, which is going to be a lot easier than
writing a provider,
all depends on what your doing....
z
On Wed, Sep 17, 2008 at 2:48 PM, RangaSatish <rtolapi at avineonindia.com> wrote:
> You are right, G/Technology is intergraph product only. It uses Oracle (not
> Oracle spatial) as it's datastore, feature geometry will be stored in column
> X1,Y1 to X8,Y8. If a linear geometry has more than 8 vertices then the X,Y
> co-ordinates will be stored in the multiple rows of the table.
> My intention is, before going for the development of a new FDO provider to
> achieve this, I want to know is some thing already availble for this
> requirement or someone already has done similar kind of custom FDO
> providers.
> View this message in context: http://www.nabble.com/FDO-provider-for-G-Technology-tp19509087p19525333.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the fdo-users mailing list
