Re[fdo-users] turn geometries
Gavin Cramer gavin.cramer at autodesk.com
Wed Sep 17 12:27:09 EDT 2008
So... is the problem that ReadNext() only returns 'true' once, or that all geometries have the same value?
Gavin
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of surrounded
Sent: Wednesday, September 17, 2008 12:24 PM
To: fdo-users at lists.osgeo.org
Subject: RE: Re[fdo-users] turn geometries
For instance, there are 44 counties within one shapefile - it only returns
one.  There are 100+ points in another shapefile, it only returns one.
NOTE: pcoords holds the geometry from GetGeometry - it is type byte[].  I
acutally pass this byte[] into another function to convert it into geometry
with CreateGeometryFromFgf.  That is why the code is not clear with the loop
and the definition of pcoords.
Thanks....
Dan Stoica wrote:
> I don't see any problem with that loop. Unless you get somehow an
> exception and the loop beaks after the 1st retrieval. But you say you get
> successfully one feature. So just to make sure: how many features are in
> the SHP file?
> Sent: Wednesday, September 17, 2008 11:45 AM
> Subject: Re[fdo-users] turn geometries
> Using shapefiles,  trying to return all geometries for all features within
> the shapefile.  Using the logic below, the geometry is returned for only
> one
> of the features within the shapefile.  How do I expand this logic to
> return
> all geometries.   Thanks....
> OSGeo.FDO.Commands.Feature.ISelect sel =
> (OSGeo.FDO.Commands.Feature.ISelect)connection.CreateCommand(OSGeo.FDO.Commands.CommandType.CommandType_Select);
> sel.SetFeatureClassName(sSplit[1]);      //Where sSplit[1] is the name of
> the shapefile
> reader = sel.Execute();
> while (reader.ReadNext())
>     pCoords = reader.GetGeometry("Geometry");
>     FgfGeometryFactory gFac = new FgfGeometryFactory();
>     IGeometry geo = gFac.CreateGeometryFromFgf(pCoords);
> http://n2.nabble.com/Return-geometries-tp1095647p1095647.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/Return-geometries-tp1095647p1095772.html
More information about the fdo-users mailing list
