[fdo-users] OGR provider in 3.4.0
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Apr 17 11:43:18 EDT 2009
If GA means General Avalibility, and is the one posted on the website as
the official one,
I have used that one with the same results.
The actual text is from a run with my own
build, which did not include the fix.
I will try to apply the fix monday and observe the outcome.
Thank you for the response.
Regards, Kenneth Skovhede, GEOGRAF A/S
Greg Boone skrev:
> This should be fixed in the 3.4.0 GA. Refer to:
> http://trac.osgeo.org/fdo/ticket/498
> Greg
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
> Sent: Friday, April 17, 2009 7:34 AM
> To: FDO Users Mail List
> Subject: [fdo-users] OGR provider in 3.4.0
> I am trying to use the OGR provider in MGE2010 and it fails with an
> unclassified exception.
> Digging a little with a custom build of the OGR provider, I can see that
> it creates the OgrConnection object
> through the CreateConnection API call.
> Then without calling any methods on the object, it disposes the object
> and returns the
> The mapguide debug log shows this for "TestConnection":
> Error: An unclassified exception occurred.
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpTestFeatureSourceConnection.Execute line 100 file
> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\OpTestFeatureSourceConnection.cpp
> And this for a preview:
>  StackTrace:
>   - MgOpGetClasses.Execute line 105 file
> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\OpGetClasses.cpp
>   - MgServerDescribeSchema.GetClasses line 1527 file
> d:\build\testarossa_nightly\build_30.1\ent\os\server\src\services\feature\ServerDescribeSchema.cpp
> Since the DescribeSchema call fails without ever calling DescribeSchema
> on the provider, I thought that the OGRProvider may be missing some
> required methods.
> I suspect that Rfc23 might be the cause:
> http://trac.osgeo.org/fdo/wiki/FDORfc23
> This may be a MapGuide error, but I was hoping that someone from the FDO
> team had tested the OGR provider with an application that uses
> the new schema functions, or could give a hint towards the problem.
> Thanks in advance.
More information about the fdo-users mailing list
