[fdo-users] Compiling FDO 3.4.0 on Ubuntu 8.04
Micho Gar michogar at gmail.com
Mon Apr 20 11:45:27 EDT 2009
Hi all, when I execute bash build_thirdparty.sh I have this error:
root at ubuntu-osmius:/home/michogar/mapguide/OpenSource_FDO# bash
build_thirdparty.sh
Configuring FDO Makefiles
acinclude.m4:7: warning: underquoted definition of FDO_HELP_STRING
acinclude.m4:7:   run info '(automake)Extending aclocal'
acinclude.m4:7:   or see
http://sources.redhat.com/automake/automake.html#Extending-aclocal
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl.exe... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking for bison... bison -y
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from gcc object... failed
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries...
yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
appending configuration tag "F77" to libtool
configure: Building with default location of FDO API files at
/home/michogar/mapguide/OpenSource_FDO/Fdo
configure: Building with default location of FDO Utility files at
/home/michogar/mapguide/OpenSource_FDO/Utilities
configure: Building with default location of FDO Thirdparty files at
/home/michogar/mapguide/OpenSource_FDO/Thirdparty
configure: Using optimized configuration
configure: creating ./config.status
config.status: creating Makefile
config.status: creating Fdo/Makefile
config.status: creating Utilities/Makefile
config.status: creating Thirdparty/Makefile
config.status: creating Fdo/Unmanaged/Makefile
config.status: creating Fdo/Unmanaged/Src/Makefile
config.status: creating Fdo/Unmanaged/Src/McToMsf/Makefile
config.status: creating Fdo/Unmanaged/Src/Message/Makefile
config.status: creating Fdo/Unmanaged/Src/FileToHdr/Makefile
config.status: creating Fdo/Unmanaged/Src/Nls/Makefile
config.status: creating Fdo/Unmanaged/Src/Common/Makefile
config.status: creating Fdo/Unmanaged/Src/Geometry/Makefile
config.status: creating Fdo/Unmanaged/Src/Spatial/Makefile
config.status: creating Fdo/Unmanaged/Src/Fdo/Makefile
config.status: creating Fdo/Unmanaged/Inc/Makefile
config.status: creating Fdo/Managed/Makefile
config.status: creating Fdo/Install/Makefile
config.status: creating Fdo/Install/XsdInstallPaths/Makefile
config.status: creating Fdo/Docs/Makefile
config.status: creating Fdo/Docs/doc_src/Makefile
config.status: creating Fdo/Docs/doc_src/group_and_page_definitions/Makefile
config.status: creating Fdo/Docs/doc_src/headers_and_footers/Makefile
config.status: creating Fdo/Docs/XmlSchema/Makefile
config.status: creating Fdo/UnitTest/Makefile
config.status: creating Utilities/Common/Makefile
config.status: creating Utilities/TestCommon/Makefile
config.status: creating Utilities/SQLiteInterface/Makefile
config.status: creating Utilities/OWS/Makefile
config.status: creating Utilities/OWS/Src/Makefile
config.status: creating Utilities/ExpressionEngine/Makefile
config.status: creating Utilities/ExpressionEngine/Src/Makefile
config.status: creating Utilities/ExpressionEngine/Inc/Makefile
config.status: creating Utilities/SchemaMgr/Makefile
config.status: creating Utilities/SchemaMgr/Inc/Makefile
config.status: creating Utilities/SchemaMgr/Nls/Makefile
config.status: creating Utilities/SchemaMgr/Src/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Lp/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ov/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Cfg/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Mt/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Rb/Makefile
config.status: creating Utilities/SchemaMgr/Src/Sm/Ph/Rd/Makefile
config.status: executing depfiles commands
./Thirdparty.sh: 27: Syntax error: Bad fd number
make[1]: se ingresa al directorio
`/home/michogar/mapguide/OpenSource_FDO/Thirdparty'
make[1]: *** No hay ninguna regla para construir el objetivo
`apache/xml-xalan/c/lib/libxalan-c.so.17.0', necesario para `all-am'.  Alto.
make[1]: se sale del directorio
make: *** [install-recursive] Error 1
Can you help me??.
Thanks.
# michogar
# Analista Programador SIG
# GNU/Linux Counter 462666
Una visión personal:
http://michogar.blogspot.com
El dia a dia:
http://twitter.com/michogar
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090420/a245b975/attachment.html
More information about the fdo-users mailing list
