[fdo-users] Update commands
Romica Dascalescu Romica.Dascalescu at autodesk.com
Fri Apr 24 10:10:36 EDT 2009
Hi Jackie,
You cannot update a field based on a calculation since the API does not offer you a method to do that.
The update command requires a FDO property value, where you may set the name and the value, but no expression may be passed, however it something definitively nice to have.
Regards,
Romy.
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng [jumpinjackie at gmail.com]
Sent: Thursday, April 23, 2009 9:50 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Update commands
Hi All,
Can IUpdate commands handle computed expressions?
For example, say I have a feature class with a datetime property "MyDate"
Can I issue an IUpdate command on that feature class to set:
MyDate = CurrentDate()
with a filter: MyDate NULL
is this possible?
- Jackie
View this message in context: http://n2.nabble.com/Update-commands-tp2689227p2689227.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
