AW: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
Traian Stanev traian.stanev at autodesk.com
Wed Aug 5 10:25:07 EDT 2009
When you use the dependency walker, try running it from the AutoCAD environment (type in the command SHELL and press Enter twice). It is possible that while libpq.dll is in the system path, it is not in AutoCAD's path environment.
You can ignore the MPR.dll and SHLWAPI.dll dependencies, they are not causing the problem.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of rgc03 at eprinsa.es
> Sent: Wednesday, August 05, 2009 2:56 AM
> To: FDO Users Mail List
> Subject: Re: AW: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
>       Hi Karl. I haven't "msjava.dll" in the "C:\windows\system32".
>       I've installed the OGR Connector as it´s said in
> http://fdo.osgeo.org/faq_mapinstall.html
>       Interesting what it´s said in
> http://geospatialfrance.typepad.com/geospatialfrance/2007/09/fournisseur-
> fdo.html .
>  I'm going to read it carefully.
>       When I use the DependencyWalker with "PostGISProvider.dll" it says
> that the files "MPR.DLL" and "SHLWAPI.DLL" are missing in my system, but in
> the installation document of the FDO Provider, those files are no mentioned.
>       Thanks a lot
>       Rafa
>       RGC
>   De:         "Hermann Karl" <Karl.Hermann at dornbirn.at>
>   Para:       "FDO Users Mail List" <fdo-users at lists.osgeo.org>
>   Fecha:      04/08/2009 19:06
>   Asunto:     AW: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
>   Enviado     fdo-users-bounces at lists.osgeo.org
>   por:
> Hi Rafa,
> Do you have already "msjava.dll" in the c:\windows\system32\ ?
> fdo.html
> check for your special dependencies with
> http://www.dependencywalker.com/
> Karl
> Von: fdo-users-bounces at lists.osgeo.org [ mailto:fdo-users-
> bounces at lists.osgeo.org] Im Auftrag von Traian Stanev
> Gesendet: Dienstag, 04. August 2009 18:20
> An: fdo-users at lists.osgeo.org
> Betreff: RE: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
> No idea why, those two builds have been specifically tested to work with
> PostGIS on FDO 3.3 (which should be what Map 2009 uses).
> Also, I don’t fully understand what you mean by “OGR connection runs but the
> PostGIS connection doesn’t”.
> Traian
> From: fdo-users-bounces at lists.osgeo.org [ mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of RGC
> Sent: Tuesday, August 04, 2009 2:31 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
>       Thank you Traian, but with the alternative provider DLL you posted it
> still not working properly. In the FDO menu, the OGR Conections runs, but
> the PostGIS conection doesn't.
>       Any idea?
>       Thanks in advance
>       RGC
> | De:        |
>   |"Traian Stanev (via Nabble)" <[hidden email]>
> | Para:      |
>   |RGC <[hidden email]>
> | Fecha:     |
>   |03/08/2009 17:44
> | Asunto:    |
> You can also try either of the following alternative provider DLL builds to
> see if it makes a difference:
> http://13-9.com/OGRProvider-3.3.0.zip
> http://13-9.com/OGRProvider-3.3-utf8.zip
> Traian
> > From: [hidden email] [mailto:fdo-users- [hidden email]] On Behalf Of
> > RGC
> > Sent: Monday, August 03, 2009 2:06 AM
> > To: [hidden email]
> > Subject: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
> > Hi all.
> > I can´t configure the OGR driver provider to my FDO conections in
> > Autocad
> > Map 2009.
> > Autocad Map 2009 needs the PostGIS 8.2.5 binaries, but in the URL
> > http://n2.nabble.com/FDO-Users-f2048584.html, I have tried several
> > links
> in
> > this download page, but it seems that none is working.
> > Anybody can tell me where can I find this binaries or send to me?
> > Thanks
> > Rafa
> > PD: I´ve tried with others versions of the PostGIS binaries but the
> > FDO connection not work properly.
> > View this message in context:
> > http://n2.nabble.com/Where-can-I-find-the-
> > PostGIS-8.2.5-binaries---tp3376079p3376079.html
> > Sent from the FDO Users mailing list archive at Nabble.com.
> > fdo-users mailing list
> > [hidden email]
> > http://lists.osgeo.org/mailman/listinfo/fdo-users
> [hidden email]
> View message @
> http://n2.nabble.com/Where-can-I-find-the-PostGIS-8.2.5-binaries---
> tp3376079p3378551.html
> To unsubscribe from Where can I find the PostGIS 8.2.5 binaries ?, click
> here.
> View this message in context: RE: [fdo-users] Where can I find the PostGIS
> 8.2.5 binaries ?
More information about the fdo-users mailing list
