[fdo-users] Disappearing Shape File Objects
Brad Nesom kidsmake6 at msn.com
Fri Dec 4 17:32:04 EST 2009
If not mistaken I have seen it with sde data also. Don't have a way to
reproduce now.
Brad
On Fri, Dec 4, 2009 at 3:33 PM, Dan Stoica <dan.stoica at autodesk.com> wrote:
>  Must be something related to data. Can I have one of these problematic
> SHP?
> It’s the first time I hear of such problem.
> Dan.
> *From:* fdo-users-bounces at lists.osgeo.org [mailto:
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Traian Stanev
> *Sent:* Friday, December 04, 2009 3:01 PM
> *To:* FDO Users Mail List
> *Subject:* RE: [fdo-users] Disappearing Shape File Objects
> You can try opening the SHP file using the OGR FDO provider instead of the
> SHP provider to determine if the problem is due to the SHP provider or due
> to Map itself.
> Traian
> fdo-users-bounces at lists.osgeo.org] *On Behalf Of *Brad Nesom
> *Sent:* Friday, December 04, 2009 2:59 PM
> *Subject:* Re: [fdo-users] Disappearing Shape File Objects
> Denis,
>   I have seen this also. I always assumed it was the display system. The
> objects are actually there they just won't display.
> Hope this helps get something started on a fix. I have seen this problem
> since 2007.
> Brad
> On Fri, Dec 4, 2009 at 10:33 AM, Denis Lalonde <denlalonde at gmail.com>
> wrote:
> I posted this in the Autocad Map3D discussion forum but am not getting any
> hits.
> With AutoCad Map 3D 2010, when opening most existing Shapefile based
> layers, via the FDO shape provider (in the “connect to data…” tool),
> many features within these layers are missing or/and randomly
> disappear/reappear as I pan and zoom the map.
> All of the problematic shape files show up fine in ESRI products as
> well as in MapGuide 6.5....so I assume that they are not corrupt.
> Also, with the latest release of MGOS 2.1, I get the same issue with
> unmanaged shape files....as I did with previous releases.
> I am assuming that this is an FDO issue and that both these products
> are using the latest DFO version.
> If there is a better place to post this message?
> Any ideas?
> MAP3D 2010 on - New Dell T3500 XP64bit.
> MGOS 2.1 - PHP, IIS, WinSever2003
> Thanks,
> Denis
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20091204/2346aaab/attachment.html
More information about the fdo-users mailing list
