[fdo-users] Fdo2Fdo uploading to Oracle
Darren Karstens darrenkarstens at googlemail.com
Thu Dec 10 06:28:57 EST 2009
I am using the Fdo2Fdo command line program to upload shapefiles to Oracle.
I have it working using the xml generated from the GUI version.
The problem im having is there is a list of <SourcePropertyName> tags
defining the names of the shapefile's fields along with
<DestinationPropertyName> to specify the name of that field in the database.
Is there any way to specify that you want all fields copied to the database
without listing them all in the XML? Or is there a way to extract the field
names from the shapefile using the command line version of Fdo2Fdo?
View this message in context: http://n2.nabble.com/Fdo2Fdo-uploading-to-Oracle-tp4144855p4144855.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
